My mp3 doesnt list my music videos when i put them on but when i try to put them onto the device again to see if it will work that time but it says the video is already on the device so my problem is is that i cant find my videos when i put them on also i go on videos and it isnt there?
when you connect it to the computer, go to "my computer" and look for it as a 'device' like the harddrive on your computer would appear (Local Disc (C:) ) and open it like a regular folder - you may have to right click and select "explore" - this should show you the available files on the device and allow you to select the option of putting your music in the music folder itself.
You need to have Windows Media Player 10 or higher. Once the device is connected you go inot the Media Player and choose SYCH. This will put your music onto your MP3 player.
All you have to do to access the files and listen to them, assuming they worked before is access the menu, then select browse all music, you will find your music files there, happens to me. To see your files on the play list section of the mp3 player, Open my computer > Go to your mp3 player > Select the music files > Right click and click add to play list.
If you add songs onto your ipod then you have to add all the song in ur music list, into its own playlist. Then drag the whole playlists title over the ipod icon and there you go. It sometimes doesnt work if you just add the songs straight from your music list. I dont know why but it's just a trick Apple has made to make life harder. hope this helps.
ok first off there are a few ways to do this the most easy way i know is just using My Computer in windows and finding the icon that is your mp3 player or is listed as a usb storage device, open that up and look for a folder called music and if none exist then try just draging and dropping your music into that folder and see if that works. Next if that wont work try opening up windows media player, then connect your mp3 player, then goto the sync button at the top of the screen and see if your mp3 player is listed if it is then go back to the media library button and start draging your music that you want on there to the sync list on the side and after your done click sync. hope this helps
may be ur pc windows has problem....i have also same problem for so many days when i connect it with my pc it doesnt show anything then i changed my windows then i connect it it shows samsung portable device in "my computer"...then enjoy with ur uploading
the first time i couldnt fix it because i ended up getting a device read error when i tried to acces it in my computer, but i think whatever caused that was different than the second time.
this time my device retained all the songs origionally on it but wouldnt reckognize any new songs. In addition to that, when i deleted all the songs off the player and only put a couple back on the player didnt register those either. so it would seem to me that it is a problem with the device's database refreshing algorithim...although thats just a guess.
neways...to fix it i copied all the data & folders off the sansa (including the .txt and .sdk files) and stored them on my desktop. After that I tried the e200 firmware upgrader available at sandisk.com
After messing around for 2 hours trying to figure out what was going on i deleted all my music, videos, recordings and pictures off the device and proceeded to format it in msc mode.
after the format was complete, i re-copied the data i had backedup on my desktop and pasted it back onto the sansa.
it seems to have worked...but then again i still don't know what caused the problem so it may not work for you. (i think it may have been something to do with one of my music files since both instances happened after i uploaded the same 5 songs onto the player)
also, i had numerous virtual folders & files that had conflicting sizes and would not open when i clicked on them (windows says they had +4GB sizes but properties says 0B also when clicked i get a file not found error).
The Limewire music is located in your My Computer> C:>Documents & Settings Folder>Administrators Documents (your name)>Shared Folder.
You can manually drag these files from this folder onto your device, located under My Computer>Device Name (there may or may not be a music folder, you should put it in there if there is).
Once you drag & drop the files, you should safely disconnect your device, then you are done.
Best of Luck.
i cant put my videos on the mp3
i put tha videos up there bt it wnt play at all
