Question about Samsung HLR5067WX 50" Rear Projection HDTV
No Input Devices
I just picked up a 50" Samsung HLR5067WX
I got it because the screen was upside down. I looked into it and found the coded menu.
well the first issue is that it returns to the upside down state whenever it is shut off. is there anyway to save this setting so I dont have to redo it every time?
second issue, which I am more worried about is that after I get it powered up it says "no input devices detected"
I have a dvd player plugged into AV1 and a cable box into the first coax.
Any Advice?
Maxx
  • 1894 Answers
SOURCE: Samsung hcn5529W hmdi input dispaly issue
then try using RY able instead of HDMI input to test if its a cable problem
Posted on Mar 29, 2008
  • 4234 Answers
SOURCE: hi! name's wesley. anyways, here's
There is a problem with the AV2 input. Since this is a new set, return it for repair or exchange. DO NOT open it up as that would void the warranty.
Dan
Posted on Jun 05, 2008
MooseMe
  • 30 Answers
SOURCE: Samsung HLN567W wavy lines
Check to see if your DVD player is outputing a progressive scan and turn it off if you are using the S-Video cable, it does not support progressive scanning.
Posted on May 14, 2009
tvrepairbiz
  • 63 Answers
SOURCE: vertical black lines on my 50" Samsung DLP TV
You need to replace the digital board
Posted on Sep 03, 2009
sabreusa
  • 271 Answers
SOURCE: HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Posted on Nov 09, 2009
I put a pcb modual in and my pic is upside down
pcb is upside down, if we are talking about the dmd?
Dec 10, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Tv screen flipped over upside down
have u just replace the main signal board if so u need to contac a sansung service center , and ask for the code to puit normal
May 08, 2009 | Samsung HL-S5086W 50" HDTV
I have a 50 in. samsung hd tv and green dots show up on my screen. how do i get rid of them.
THE CONTROLL BOARD IS BAD  COULD BE INTERMINTENT BUT ITS GOING OUT NEEDS TO BE REPLACED WHAT MODEL IS IT? YOU COULD TRY  PRESSING MUTE 1-8-2 WHILE SET IS OFF THEN PRESS POWER TO ACCESS THE SERVICE MENU THE GOTO USER RESET THAT MAY SUBSIDE THE PROBLEM
Feb 21, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Hdmi input doesn't work but component in works fine. When plugged into hdmi all you get is a blue screen
What are you attempting to use HDMI for? Sometimes you have to adjust the settings of the system that is using the HDMI connection. The tv needs to reset to HDMI
Mar 26, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Vertical lines on sansung hln5065w tv
Bring up the on screen menu if you see the lines in front of the menu replace the DMD board.
Feb 19, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Auto focus problem SAMSUNG SP-48T5HP
It needs to most likely be re-initilized in a technician service menu. If the convergence looks fine otherwise this is most likely the cause.
Mar 02, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
