Question about Panasonic Video Cameras
Panasonic VW-SHM10 Video cassette door won't stay shut
Panasonic VW-SHM10 - Video cassette door won't stay closed, I think maybe the small plastic part that holds it shut is broken, but I'm not sure.
SOURCE: panasonic nv-ds65b camcorder
Maybe battery is low charge or broke try conection with adapter
Posted on Apr 21, 2008
  • 319 Answers
SOURCE: Cassete door will not stay closed
Unit may have jumped mechanism timing. Take in for service
Posted on Aug 01, 2008
satavlad
  • 405 Answers
SOURCE: Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Posted on Dec 04, 2009
Testimonial: "Thanks. We ended up getting a new camcorder. That Handycam was as old as I am (18 years), so it was time for an upgrade anyway."
  • 49 Answers
SOURCE: WILL NOT HOLD A CASSETTE. VIDEO ERROR READS
normal dew indication is from moisture if you can find any desicant out of pill bottle sometimes in new electronics the desicant can be ractivated by placin in oven at 220 degrees basically above boiling point
15 to 20 minutes let desicant cool place camara and desicant in tight sealed container or plastic bag let set overnight see if moisture problem goes away
Posted on Dec 06, 2009
SOURCE: i cant eject my Panasonic NV-GS55 Mini DV Digital video cassette
Try ejecting cassette whilst powered from AC Adaptor. Secondly, try operating Eject from powered off mode. If operation LED starts flashing after any of these attempts, the mechanism is probably jammed or has become mis-timed. Unfortunately this requires professional intervention to avoid further damage to your equipment.
I hope this information is of assistance!
Posted on Jan 01, 2010
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
hi,
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
Oct 26, 2015 | Panasonic Palmcorder PV-GS12 Mini DV...
Draw will not close
Look under the drawer and look for a plastic pin sticking up. This pin needs to be in the track on the bottom of the drawer for it to close and load correctly.
Feb 22, 2013 | Panasonic DVD-XV10 DVD Player
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
Panasonic m7 vhs video camera while in play mode camera stopped and made whiring noise then shuts right down will not eject how do you get tape door open manually
Hi, open eject door,try to see very small lever at the left side cassette at lower end and try to pull it at your side with very thin and at least 4 inch long screw driver.Cassette compartment will open. But its not so easy to find.It need patience.
Aug 10, 2010 | Video Cameras
CASSETTE ADAPTOR VW-TCA7E tab won't retract when I place the video camera cassette in the adaptor and close the cover. The triangle-shaped tab is on the left side of the adaptor and when it has not...
I had a similiar problem, or so I thought, but my son has just found that it needs a battery, which I did not even know, so maybe yours just needs a new battery? the cover is near the tab, hope this helps
Apr 20, 2009 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Aj-d200 video camera, cassette door stuck partially open. best diagnosis and/or remedy?
Partially open sounds like a mechanical problem with the cassette housing/door assembly. The door usually stays fully open or will not open at all, caused by component failure on the mechanical driver board. Check to make sure nothing is stuck in the mechanism, like a label or a broken piece from a cassette. If the door will move, but will not latch closed, the problem is most likely on th emechanical driver board.
Mar 25, 2009 | Panasonic AJ-D200 Camcorder
Camcorder Will Not Close
This is due to the improper closing of the cover below the cassette compartment(where the USB, 3894 ports r there)
Pl. close it properly. Then open the cassette door completely, and then close. It works.
Dec 07, 2007 | Panasonic Palmcorder PV-GS15 Mini DV...
Panasonic nv-ds65b camcorder
Oct 15, 2007 | Panasonic NV-DS65 Mini DV Digital...
Video Cameras Logo
257 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
