Question about Dynex DX-WC100 Webcam
Dynex webcam, built in mic won't work on msn.
Ok so i got a dynex webcam with a built in mic. the mic works perfectly fine when i test it by going into the control pannel etc. and when i try to use it on msn to record voice clips or have video calls, it won't work. help?
    Scholar:
  • 33 Answers
I have a different Webcamera, but this should work. Please rate/vote me if it does! Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Posted on Aug 06, 2009
Hi, my Logitech webcam is doesnt work on Windows Live Messenger, its only works in Skype. How can I fix it?
Set your webcam mic (if it has one) as default
If you have an earlier OS than Vista, you may have to access your hardware from the Control Panel and set the default mic from there - make sure its plugged in.
VISTA
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in, after a few seconds, to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Aug 23, 2010 | Logitech Webcam
I installed my wecam but when i try to go on a coversasion on windows it wont work
VISTA
Plug in the webcam
TEST SPEAKERS
Restart computer
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Aug 23, 2010 | Logitech QuickCam Express Web Camera
Have a built in dell webcam and cannot work with skype
VISTA
Plug in the webcam
TEST SPEAKERS
Restart computer
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Aug 23, 2010 | Logitech Quickcam Chat Webcam
People cannot hear me
If your webcam has a built in mic make it the default mic
XP
Control Panel (Classic View)
Plug in your webcam
Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your webcam mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Vista
Plug in the webcam
TEST SPEAKERS
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
Restart computer
Configure your webcam to the chat program
Aug 22, 2010 | Logitech Webcam
I can't make my webby work with msn. it works off
Plug the webcam in and set your webcam mic as default
TEST SPEAKERS
Restart computer
Set your webcam mic (if it has one as default)
Vista -
Mine, I just unplug it from the USB and plug it back in to reboot the software.
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Jul 15, 2010 | Microsoft LifeCam VX-1000 Webcam
I can't fix my michrophone on msn, even i tried the tools maybe because when i got the windows 7 , i saw many things has been changed on my computer , plz help
If you have a laptop you will 2 mics - try making the webcam mic default
TEST SPEAKERS
Restart computer and configure to msn
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Jul 11, 2010 | Logitech QuickCam Pro 5000 Webcam
Installed Philips SPC630NC web cam will not display picture on Msn Messnger live just a green screen, all drivers have been checked and software but just a green pictur, it wont work on any other cam site...
Vista
TEST SPEAKERS
Restart computer
Vista -
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Jun 15, 2010 | Philips SPC 630NC Webcam Fun - Web camera...
Well I have a msi laptop and the built in web isnt working and I checked if it was on and it says it is. But when I go to skpe or msn nothing happens and the little light beside it doesnt go on? I need...
You will have to set up or configure your webcam software to work with any chat program before you can broadcast.with it.
If it has a built in mic with the webcam -Make it your default mic.
TEST SPEAKERS
Restart computer
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Vista -
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Jun 13, 2010 | Computers & Internet
I have logitech webcam logitech mic but cannot get the mic to work through windows live webcam works
Typical audio set up
Laptop x webcam/mic x Vista x MSN Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
CONFIGURE TO MSN MESSENGER
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Click 'Finish'
Jan 10, 2010 | Logitech QuickCam Communicate STX Personal...
My built in webcam wont work on msn
Test it here by clicking 'allow' in top window
If it works OK you need to configure it to WLM
Open menu > Tools > audio and video set up - set mic as default if it has built in mic and test audio > Next - set webcam as default and tune picture using settings > Finish
Sep 29, 2009 | GE MiniCam Pro HO98756 Webcam
Dynex DX-WC100 Webcam Logo
590 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
