Question about Garden
Honda powered lawn mower will start, but wont rev
Starts real easy, but wont rev. any ideas what to look for?
5 Suggested Answers
  • 37 Answers
SOURCE: Heavy smoke when you first start the engine
Hi. sounds likes too much oil in engine or if you tilt the mower up&down or side to side.
if you need more help, just write again
Posted on Nov 21, 2008
canbruce75
  • 1776 Answers
SOURCE: Racing of a Honda 160 CC lawn mower engine
When a small engine "surges" in all speed ranges the possible causes are:
*Dirty air filter
*Water or contamination in the fuel system.
*Breaks in the spark plug wire (leaking), loose or corroded terminal connections causing an intermittent failure.
*Misadjusted or malfunctioning governor.
Problems with surging only when under load or at idle are likely caused by carb blockage or misadjustment.
Hope this helped and good luck to ya!
Posted on Jul 20, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Honda mower wont start
where do you spray the starter fluid in the carb or the spark plug hole?
Jul 17, 2014 | Honda Garden
M48a wont rev
Check cable that is not loose when you adjust power or check that there's nothing rapped around the blades could decrease the power it's supposed to give when blade is spinning
Jan 03, 2014 | Garden
Talon mower wont rev
may have to bend arm where governor spring goes
Jun 10, 2013 | Talon Rotary Lawn Mower
High Revving Honda Lawnmower
When you put the carburetor back on did you get the linkage springs put back in the correct place? If you have a governor spring off or in the wrong place it will run fast. Running at an RPM higher than the recommended one can cause severe internal damage but shouldn't cause it to be hard to start. The hard start can also be from an incorrect linkage connection
Dec 17, 2012 | Garden
Honda HR 17 lawn mower dies after it starts
01 Fuel tank cap? Loosen it to see if it is plugged.
02 Possible fuel line obstruction? Disconnect at carb to make sure there is adequate fuel flow.
Apr 19, 2010 | Garden
Lawn Mower wont start
You need to obtain a manual for Briggs & Stratten engines. All the info you need will be in it. The most common cause for non starting in these engines is "Tight Tappets" Wether it's an OHV or the old "L" head engine, because they rev and work so hard, the valves seat themselves deeper into their seat which reduces the valve clearance. There is no adjustment on the older "L" engines, so you have to remove metal from either the valve stem, ot the lifter itself. I have in the past done this in situ with a point file, but it is a tedious job. Otherwise you must remove the head and take out the valves and grind the stems. A tricky task and probably should be done by a mechanic.
Apr 06, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
187 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
