Speakers not working.................
I have the above pc & i cant get my 2.1 speakers to work, i've tried connecting the speakers to my fujitsu laptop via the jack plug & they work fine......there are 3 connection that look like jack plugs on my scalo p- pink blue green........how do i get these to work....help please Hi There Try this, CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them with a new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps HI I'VE TRIED ALL OF THE ABOVE SO FAR, I HAVE HAD THE PC REBUILD DUE TO A PROBLEM, I BELEIVE THE DRIVERS HAVE NOT INSTALLED FOR THE STANDARD SOUND CARD, I NO LONGER HAVE RESTORE DISK...........DOES ANYONE HAVE A LINK SO I CAN DOWNLOAD SOME DRIVERS? OR OFFER ANOTHER SOLUTION.....THANKS
  • 1 more comment
  • jorge4 Nov 25, 2007
    My computer was updated everything was erased so I connected everything is working exept my audio a cant hear music or nothing at all. I went into into control panel did everthing step buy step and nothing I put the recovery cd and cliked on audio and no response. Can you please help
  • cporeilly Dec 09, 2007
    I can get my spekers to work, the problem is they are very low.
    I have updated to the latest version of the Realtek HD Drivers, R182, but am still having the same problem.
    Is there any way to check to see if the soundcard itself is faulty? I have tried multiple cables, tried using a straightforward 3.5 mm stereo cable to the monitor's PC sound input conection, and a 3.5 mm to RCA type left & right cable, connecting to the monitors's HDMI audio input, same with each option.
  • crypto-jack Aug 04, 2008
    my speaker are not puting out sound what shoud i do
    Problem Solver:
  • 13 Answers
Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • Speaker Cable is connected to an audio port (Audio/Video port in system box).
  • Volume is MUTE / Low (in Volume Controller).
  • Audio drivers have installed.
To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System Properties Window)
• Select “Hardware” Tab>
• Select “Device Manager” Tab> (it shows the Device Manager Window)
• Select “Sound, video and game controllers”>
• Expand “+” symbol> (check the audio Codecs, Legacy Audio Drivers and others are not in Questioned Mark (?) symbol with yellow color. If there need to install the drivers ).
  • If not, insert the motherboad CD, browse>select audio driver>install. After completion, restart computer and check.
Posted on Dec 22, 2009
My spaker are macking a fun sound but when i play some it dos not have eney sound at all.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Aug 04, 2008
    Sergeant:
    Champion:
  • 293 Answers
What's the exact model of your PC \ Motherboard?
Posted on Sep 21, 2007
3 Suggested Answers
PcExpert
  • 293 Answers
SOURCE: siemens fujitsu scalo p.....can't get my 2.1 speakers to work
Hi There Try this, CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them with a new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps ======================= If you are having trouble with Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 19, 2007
  • 38 Answers
SOURCE: fujitsu seimens scaleo P
Easiest way is to find the drivers through the "connect to internet" option which you get once you click on update/re-install drivers in the device manager. Sometimes this process does not work, so in that case you go to fujitsu site, support,choose your PC model and download drivers. Another option, go to driversguide.com, specify your PC model & download drivers.
Posted on Sep 25, 2007
DNS server or whatever...
Check your firewall is turned on or not.
Hold down the Windows key and press R. (This will open the Run dialogue.)
  1. Type "cmd" and press Enter. (This will open a command prompt.)
  2. Type "ipconfig /flushdns" and press Enter.
  3. Type "ipconfig /registerdns" and press Enter
  4. Type "ipconfig /release" and press Enter.
  5. Type "ipconfig /renew" and press Enter.
  6. Type "netsh winsock reset" and press Enter.
  7. Reboot the computer.
May 08, 2013 | Fujitsu Siemens Computers & Internet
My ASUS K50IJ sound comes from only one speaker. I've tryed everything and the balance seems ok
One of the speakers failed or it has a bad connection.Most likely the non working speaker will need to be replaced.
Mar 29, 2013 | ASUS K50IJ-C1 Notebook
Only one of my two headphone jacks plays sound
you can use a usb sound device its very cheap 2 $ in value
Feb 02, 2013 | Dell Studio 1737 Laptop
Hi having problems with my partners Fujitsu Siemens ScaleOP Desktop Computer. She recently reformatted the PC with a Genuine copy of Windows XP which installed perfectly without any hitches but when...
Can the drive read other disks? I'm guessing no. If no, it would appear as if the drivers for the CD rom are not loaded. If this is the case, you will need an internet connection to download the drivers for the cd rom so it will work. Other than that,you can try to install generic cd rom drivers through windows, that may work. Good luck.
Sep 26, 2012 | Computers & Internet
I just got a new power supply installed in my Fujitsu 50in. Plasma P50XHA4OUS and cannot get the sound to work, we've tried everything, please HELP!
Assuming the power supply is exact replacement and you did not have this before--check the speakers to make sure not turned off.
If using a cable or sat box make sure sound not way down or off both with the set and the box.
Last but not least if sound is there with a DVD---something somewhere is set to wrong position.
Apr 27, 2012 | Fujitsu 50 in. Plasma TV
Need to access fan on fujitsu c2220
1) ALL power removed from the laptop. Remove the AC adapter (Charger) and Battery.
2) Observe Anti-Static Precautions.
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
You will be touching the motherboard, and can Static shock a number of hardware components.
Advise you purchase an ESD wrist strap, and connect it's alligator clip to a good ground source.
Average cost of an ESd wrist strap is around $3 to $6.
Example;
http://www.radioshack.com/product/index.jsp?productId=2103245
{ I connect to an unpainted surface, of the metal frame of an empty desktop computer case.
If the table you're working on has metal legs, connect to an unpainted surface on one of the legs.
If none of the above applies for you, at least place a large metallic object on the table, and connect to it. (Unpainted)
Perhaps a metal serving tray, or large metal knickknack. (Unpainted}
3) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available you can substitute with a clean egg carton.
Label each egg holder.
SOME screws look VERY similar to other screws. DO NOT mix them up!
{ For example: If you install a wrong screw in a hole you chance it binding up in the hole, halfway in.
Try to take it out, and you may strip the threads off of the screw, and the hole. If the hole is in the motherboard, you've GOT problems}
4) Make a record as you disassemble. A personal record is nice to refer back to in case you are interrupted.
It is also p-e-r-s-o-n-a-l, so YOUR information is more concrete for YOU.
Make notes, and drawings, and/or photos.
5) I do not work on Fujitsu laptops all that often. My service information is very small as for Service Manuals. However, through the years I've found all laptop disassembly, seems to follow a basic pattern
I'm hoping this information crosses over to your Lifebook C2220 Notebook PC,
http://mycapsules.com/disassembly/fujitsu-s2110/cpu
Looking at the photo you will see Step 1 of 29 above it.
To go to the next step click on - next - in blue, or press the p key.
Fortunately for the Lifebook models, the cooling fan can be accessed from the top of the motherboard.
The Keyboard, Palm Rest Cover, (Upper Case), and Static Shield, are removed.
The Cooling Fan is right there on the left. (Two Philips head screws are removed, then the cable's white connector is unplugged from the motherboard)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 17, 2011 | Fujitsu Siemens LifeBook C2220 Notebook
Cant hear the other person in voice chat
uninstall the the skype and reinstall it back, that should work
Jul 03, 2009 | Lenovo 3000 Y410 Notebook
I speakers to my laptop
You need an amplifier between Laptop/PC jack to drive the high power speakers/subwoofers. Or buy the special system like Logitech's Speaker system (speakers-subwoofer) that has a built in amplifier already designed for PCs/Laptops. Radio shack has amplifiers of various inputs and power levels.
May 23, 2008 | Computers & Internet
Fujitsu seimens scaleo P
Sep 23, 2007 | Computers & Internet
Siemens fujitsu scalo p.....can't get my 2.1 speakers to work
Sep 19, 2007 | MPC Computers ClientPro 414 All-In-One PC...
Computers & Internet Logo
1,357 people viewed this question
Alun Cox
David Payne
David Payne
