Question about Plumbing
I am installing a new kitchen faucet and have two problems. Number one the plastic flange njuts that hold the old faucet to the sink won't come off. I tried to loosen them with WD-40 and white vinegar. No luck. I can't seem to get a wrench to grip it. Second, I bought new vinyl mesh supply lines to replace the old rigid plastic ones. The old plastic has a 1/2 nut on one end and a 3/8 or 1/4 inch threaded nut with a compression ring on the other end fitted to a copper pipe. I tried to loosen the nut that held the threaded 3/8 or 1/4 threads figuring it was screwed on. It wasn't. It was soldered and I broke the seal with my wrench. Is there a product I can use to restore the seal so I can go back to the hardware store and buy other supply lines. I guess they still make the rigid ones.
    President:
  • 1,489 Answers
First of all, you need a faucet wrench. It's about 12 inches long, has a t-handle on one end and jaws on the other -- this will grip the plastic nuts to remove them.
I'm not sure what is meant by breaking the seal. If the soldered fitting broke loose, the best approach is to cut the copper pipe off past the damage and solder a new fitting on it necessary for the new hose to screw onto it.
There are a lot of ways to solve this problem -- if you can't manage the soldering, we can discuss other options.
Posted on Apr 21, 2009
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
Base of single handle kitchen faucet is loose where it sits on the counter
there should be 2 plastic nuts under the sink that hold the fixture tight to the sink. if they are tight allready try to install washers and see if that helps. right is tight. left is loose.
Jun 08, 2012 | Delta Faucet Plumbing
Remove bathroom sink flange
Turn off the water valves at the back of the sink and place a bucket underneath the drain to catch any water that may run out.
2 Loosen the nuts that hold together the drain tailpiece and the P-trap with a wrench. Disconnect the the two pieces.
3 Unscrew the drain tailpiece from the drain flange. Depending on how the drain flange is held in place, you may need to hold it down firmly as you twist the tailpiece below. Remove the tailpiece and set it aside.
4 Remove the old drain flange. It may come straight out after the tailpiece is removed, or it may be held in place with putty or silicone. If it is held in place tightly, grasp the edge with a pair of pliers and pull until it comes free.
5 Wipe down the sink area that was underneath the old flange. If the metal was discoloring or rusting, clean the porcelain well and dry it to keep the new flange clean.
6 Apply a thin bead of silicone caulk to the underside of the new flange. Push the new flange into the drain hole in the sink.
7 Push the drain tailpiece back up into the sink's drain from below and screw it into the flange tightly. Use a wrench to tighten it up securely.
8 Reconnect the P-trap to the tailpiece and tighten the nuts that hold it in place. Turn on the water supply to the sink and run water through the pipes to ensure everything is securely fastened.
Things You Will Need
  • Bucket
  • Pliers
  • Adjustable wrench
  • Silicone caulk
Duplex Steel flanges Duplex Stainless Steel Flanges Manufacturers Suppliers Instinox
Feb 12, 2012 | Kohler Plumbing
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
New moen kitchen single handle. Worked for one full day. Now no water pressure.
Unthread end of faucet (aerator) where the water comes out into sink, under the aerator is a screen & a plastic valve.It has sediment & rust which will disrupt the flow & pressure.Careful not to flush it down the drain. Tip upside down, while holding it together with finger. Flush it under the faucet. It is not uncommon to get plugged up initialy because of the new installation.
Nov 01, 2010 | Moen 7310 Legend Single-Handle Kitchen...
How do I fix my kitchen sink faucet?
he steps to replace a faucet are easy and nearly always the same. Here's how it works:
  • Shut off the water supply to the faucet. Usually, there are shut off cocks near the faucet but if not, you may have to shut the water off near your main line.
  • Remove the water feed lines from the faucet. You may wish to tag the hot water line "hot left" to take the guess work out of reconnecting.
  • Remove the faucet hold down washers or spin nuts. These washers are under the counter top. They spin onto two studs that you will see by looking behind the sink from below the faucet. The stud and washer configurations come in different styles and types but they all do the same work of holding the faucet in place. Your job is to get them loosened up so you can remove the old faucet. The distance between those studs is your "center distance" as mentioned earlier.
  • Once you have the faucet loose, it will be much easier to remove a sprayer line if there is one attached.
  • Clean the area once the faucet is removed.
  • Put the new, plastic faucet base plate in position.
  • If there is a sprayer, replace the base for it (included in the kit) and feed the new line down through the sprayer base and back up through the center hole where the faucet will mount. Attach that line to the new faucet.
  • Insert and firmly yet gently tighten the mounting studs into the bottom of the faucet base if they're not already.
  • Insert the faucet into the appropriate location on your sink and install the faucet hold down washers or spin nuts.
  • Reattach your water lines. Begin by lightly cleaning all threads with a soft cloth and then apply Teflon plumber's tape to the male threads of your connections Be careful not to cross thread anything when putting the connections together.
  • Reestablish water pressure and check for leaks. It always helps to have a spotter / helper for this step.
A new kitchen faucet always gives me a special DIY feeling because a new faucet looks good, operates easier and can even save a little water by providing quick, positive shut off. Take your time and survey the entire job before you start. With a little time and patience, you too can have a bright new faucet in your home kitchen.
Jan 02, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
I have a new hose for my Grohe Euro Plus to replace a leaking old one. I have disconnected it from the water supply but now the ends of the the old hose will not fit through part connected to the sink...
There are 2 sets of nuts and washers underneath the faucet that holds the faucet in place. loosen them and the water lines (after turning the water off) faucet lifts off from the top of the sink. Replacement the the same, just in reverse. BE SURE TO USE TEFLON TAPE OR PLUMBERS PUTTY ON THE WATER LINE THREADS TO PREVENT COSTLY LEAKS.
Jun 20, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Wobbly faucet on new elkay sink
this faucet comes with diffrent hold downs for diffrent sinks on is wider for stainless sinks the other is smaller for granite or corian sinks, it sounds like your plumber might have put the wrond spacer under the facet where it mounts to the sink,, it doesn't matter the sink or the faucet they all come with proper adapters, and I do know that moen and delta have them in the box with the faucet,,, good luck with yo people, this faucet of yours even comes with the plastic tool to put the faucet in because it has a long shank with threads on it and is hard to get a wrench on
Jun 07, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
Plumbing Logo
98 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
