Question about Car Audio & Video
I have a power acoustik ps2-2600 it went out this morning the red light was on i checked the ground it was fine when i unhook the remote or the audio cables it turns off if i hook up the audio alone it does nothing if i hook up the remote it turns red again not sure whats wrong have you heard of this before
    Problem Solver:
  • 8 Answers
Unhook all the cables including power let sit for 15 minutes and than hook up the ground rca cables remote and than power in that order with the car off and the battery unhooked that hook the battery up the amp went to protect mode to keep it from blowing i hope your amp isnt like some that only the factory can reset most amps arent and reset themselves
Posted on Apr 21, 2009
The green light on my amp doesn't turn on.
You need to check Constant power, Ground, and also the remote turn onwith a 12v power
if all this seems fine then it seems like your amp is damaged
PS
check the fuses right next to the amp that might also fix it
Dec 06, 2010 | Power Acoustik PS4-800 Car Audio Amplifier
I have a power acoustik bamf 1600/4. not working 5 hours later
use a multimeter to see if the amp has good power wire and remote turn on voltage. then check the ground and make sure its a good strong ground. check the sub to make sure its not bad. make sure it reads whatever ohm its supposed to. anything less than 4 ohms will clip the amp if bridged. if alll that is good then the only thing left is the amp. it sounds like the power supply is bad but check everything else just to make sure. good luck.
Dec 29, 2009 | Power Acoustik BAMF1600/4 Car Amp
Amp stuck in protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Good Luck.A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 22, 2009 | Power Acoustik Car Audio & Video
Red light keeps flashing..
my kicker was doing the same thing, and come to find out the power was loose,
1.check power connection,
2. check ground
3. check remote wire.
4. check that your amp isn't mounted on -metal-
5. check your fuses onboard the amp,
6.check you speaker wire
7.check your rca jacks
8. check that your gains aren't too high for the wattage
May 12, 2009 | Power Acoustik PS2-1250 Car Audio...
Amp light is neither green or red
have u connectted the remote wire from head unit to turn amp on? have u got + and - the rite way round.hope this of use.
Mar 05, 2009 | Power Acoustik PS2-1250 Car Audio...
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
MH master
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 16, 2008 | Power Acoustik TS1440-2 Car Audio...
Red light
It sounds like the output transistors have failed. Disconnect everything from the amp except for the B+, ground and remote and turn the amp on. If it goes into protect, the amp is in need of repair. If you want to repair it yourself, email power acoustic for the schematic.
Oct 02, 2007 | Power Acoustik LT-980/2 Car Audio...
Power Acoustik
the amp shouldnt even lite up w/o the ground attached.
Jan 25, 2007 | Power Acoustik GOTHIC OV2-520 Car Audio...
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
