MFC8440 copier/scanner/fax the cover is hinged with two hinges: a smaller right hinge and the left hinge a type of split spring switch that moves up and down in the base of the copier (probably to allow for thicker documents being copied). The lid/cover attaches to the lower part of this switch unit using a pin approx. 1-3/4" long. I am trying to identify and locate the lower part of the switch/hinge as the plastic ears on either side that the pin goes through has broke of and no longer secures the lie/cover.
  • steve656 Apr 21, 2009
    At present, the part looks the same and your efforts and response were exemplary of a top notch company. I will definitely use your site again.
    thanks
  • 298 Answers
If its the left hinge that is busted you can order a replacement here > http://www.precisionroller.com/find/h7914.htm
Reply back if that is not the right part.
Thanks,
Mike
Posted on Apr 20, 2009
Hing broke on copier can i get parts for that
Spare parts are available here (Brother MFC8440 Doc Feeder Parts).
Left hinge is one part, right hinge requires one or two separate parts
LP2403001 HINGE ASSY Left
LE6244001 HINGE BASE Right
LE6245001 HINGE ARM Right
Dec 29, 2010 | Brother MFC-8440 All-In-One Laser Printer
I changed a printer cartridge and the lid is stuck open. HP 3310 Photosmart. I did reseat the cartridge I changed to no avail. I am most curious how this can be fixed without forcing the lid down. Thank...
hello, well, you can take off the right cover, with printer unplugged, and disconnect cables that connect to the scanner top cover area. the hinges have press lock that will require you to press up, and slide towards the front and lifting up at same time. the scanner will come off, using #10 torq bit, take hinges out of machine, if you some white grease or light weight lithium oil, use it in and around the actual hinge area, basicly what your working against is plastic on plastic, with a powerful spring, so do this carefully and try not to pinch your fingers, it hurts alot. try slowly to open and close hinge slowly, if it does not move freely, don't force or it will break, that spring used is under alot of pressure, so do it slowly, lube and try to move, lube and try to move. when it works smoothly put back together
Oct 12, 2010 | HP Photosmart 3310 Printer
Doc cover open errror message on a mfc-8840d and cant' seem to print anything and the mode always is in fax mode and we can't seem to change it.
That error happens when the left hinge in the back breaks and the scanner cover won't shut all the way. temporarily you can tape the switch that is above the hinge and when the error is gone the modes should change again. The hinge is #LP2403001.
Oct 16, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC8440 - Left Hinge Assembly broken
Brother will not sell to end users, contact a Brother Dealer in your area.
Jul 26, 2009 | Brother MFC-8440 All-In-One Laser Printer
Need replacement part-Left-side hinge (holds 2 springs) broke off
Go to this website called Precision Roller and they have the left-side hinge:
http://www.precisionroller.com/manufacturers/brother-mfc8440.html
Go about halfway down the page and its there. They sell genuine brother parts.
May 23, 2009 | Brother MFC-8440 All-In-One Laser Printer
Parts for Brother MFC 8200D
Yes, I had the same problem in Sept 2006 - a broken left hinge that needed fixing. Ordering the part was easy. I was able to install it myself, but it required some attention to detail.
I called Brother International at 800-284-4357, Option 1, then 2. I ordered the left hinge - Part No: LP-2403001 - described as ADF Hinge Assembly (left). If you broke the right hinge, the part number may differ slightly, but person on phone should be able to assist. It cost me $11.55 including shipping.
Feb 28, 2008 | Brother MFC 8820D All-In-One Laser Printer
My MFC8440 Cover Left Hinge Brocken
Very common part any brother dealer can get it. Ring brother to find closest dealer about 20 bucks
Dec 06, 2007 | Brother MFC8440 Remanufactured Laser...
70 people viewed this question
k24674
jasbo
jasbo
