Question about Sony KP-65XBR10W 65" Rear Projection Television
SONY KP-43T75 HAS ISSUES
THE TV IS SHOWING GREEN.ALSO IS SOME WHAT OUT OF FOCUS. NEED TO KNOW HOW TO CONVERGENCE THE TV. DON'T KNOW HOW TO CONVERGENCE THE TV. I HEARD THEIR ARE CODES THAT MIGHT HELP TO CLEAR THIS UP, BY USING THE REMOTE.PLEASE HELP. CAN'T AFFORD A REPAIRMAN AT THIS TIME HAVING A BABY.
  • 2 more comments
  • darinj Nov 08, 2007
    i changed the red bulb in my tv, now i need to know how to adjust convergence ANY hep would be great
  • jeff Sep 26, 2008
    sony kp 43t75 problems my tv when you push the power button you can hear the sound and the red led light blinks 20 times then the picture comes on. The red is out of line a little.
  • Anonymous Dec 03, 2008
    tv is out of focus and i need the code to program my remote to work for the sony KP-43T75
  • 1747 Jan 13, 2009
    Picture is double vision in red?
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common prSONY KP-43T75 HAS ISSUES - 2c07611.png/>
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of aSONY KP-43T75 HAS ISSUES - 578ba6c.jpgeeds the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 28, 2009
  • Edward
    Edward Dec 11, 2009
    Let us know if the solution above worked.
    Genius:
  • 1,153 Answers
Is this complete green or just green edges? If complete green then it sounds like you have lost your red and blue guns. I would take back off and look up in set and see if red and blue are lit. Then I would turn Screen control up just a bit to see if red or blue comes back, remember if don't see the red or blue come up then turn back down, also focus is on this block also, but you would have to focus one color at a time. Hope this helps!
Posted on Sep 21, 2007
Out of alignment (red)shadow
Ur tv convergence are dead.U must know how to solder.U must have soldering tools,and solder to fix convergence problems.Must repalced 2 STK convergence ICS and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 15, 2010 | Sony KP-57WS500 57" Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
T.V will not come on
replaced both shorted convergence ics
Jul 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KP-43T75 color repair
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
I hope this helps you!
Fare well. :)
Iconoclast
Jun 27, 2009 | Sony KP-51HW40 51" Rear Projection...
KP-43t75 no picture black screen, Menu comes up bowed
Ur convergence it dead.Buy a convergence kit,replaced what in that kit.Know how to solders right?Buy a convergence kit in these websites Tv repair World.com,Tv rpair Kits.
Feb 04, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
well sound like convergence for one and maybe another problem. First look at customer settings and look at convergence and try to realign. Then you can in Standby mode(Power Off) Press Display 5 Vol+ TV power on Remote. Fast. Now do you know what you want to get to? Because changing things here could cause serious problems with your set.
Sep 21, 2007 | Samsung TXM3281HF 32" TV
Audio problem
Audio issue may be the cable. The green picture sounds like a convergence problem. Try to adjust the convergence in the menu and if that does not fix it you may need to get a repair facility out to take a look at the convergence amps.
Jun 06, 2007 | Sony KP-51WS520 51" Rear Projection...
Sony KP-65XBR10W 65" Rear Projection Television Logo
1,141 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
