Question about Carrier Heating & Cooling
Knock Noise When Carrier Furance Starts Up
I have a five year old Carrier Weathermaker 9300TS furnace. Earlier this year I had to have the blower motor replaced for the first time. Within the last week or so when the furance starts up, the motor is in a low speed to clear our fumes...when it gets into the next speed to start heating the air, I hear a knock, sounds like something metal hitting. Before I call the repair company that charged me almost $600 for the blower motor, any suggestions on what this might be doing to cause the knock? Other than that, the furnace is working fine (and hopefully for a long time).
  • 38 Answers
Have the ac company check the actual blower wheel itself it may be slowly coming apart
Posted on May 07, 2009
  • gregory80
    gregory80 Nov 27, 2012
    I have the same problem except my furnace is 2 months old... the company owner came over and said... "since your furnace is on the main level you can hear it, most furnaces are in the basement." Then he left...
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
I am hearing a little bit of squealing noise when running the ventilation fan in my house.
Sounds like you have a bearing going in the blower unit or a loose belt. Get it serviced by a reputable service company.
Oct 20, 2014 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a carrier 58RAV050-12 and my furnace won't turn on. It was working earlier today but it just stopped. Any suggestions as to why?
Check the pilot lt. If its out shutdown your furnace and call a repairman. If the pilot light is on, the flame sensor might have gone out. It's a long silver sensor that sits in the pilot light flame and senses when the flame is present. If it isn't working the furnace will automatically shut down.
Nov 04, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Furnace Operations
Yes, That is normal for many furnaces, not just the Carrier...
Seems to be a bit dumb but then the ones who desogn these things are sitting behind desks and not out in the field working on them. I'm sure they have a perfectly good reason to have the furnace do that but I have never figure it out....
It does get your attention when the furnace is there running for ever, blowing cold air and burning up your electric....
You just hope that it does not happen when you are away for an extentend period of time...as you said.
Always make sure that if you have someone checking in on your place that they verify the temperature and not just peek in and say yup the furance is running...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Jan 01, 2010 | Heating & Cooling
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 58mvp furnace ecm motor is making viberating noises
ecms are pretty reliable and electronic failure is much more common than bearing or bushing wearout. i suspect the fins on the blower may be coming loose from their pressed on spline and that will start a vibration or shimmy or you could have thrown a weight that balanced the wheel . best to use to warranty to get a new wheel. good luck
Dec 07, 2008 | Carrier 38CKC036 Air Conditioner
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Changing filter
The filter should be located in the return air flow duct either inside the furnace or in the ductwork
you should have it inspected by a service contractor
as far as when it should be replaced depends on the condition of the heat exchanger and overall condition of the rest of the parts it could start to nickel and dime you
Dec 31, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
476 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
