Question about NetGear WGR614 Wireless Router
Bandwidth speed always scales down to 24mbps
I'm using a Trendnet PCMCIA 54mbps card and a Netgear WGR614v1.1 router. How can I make it go up to 54mbps. The bandwidth always scales down to 24mbps even when the laptop is right beside the router.
    Brigadier General:
  • 6,966 Answers
Hi, A couple of things you can try: 1. Remove any security setting (WEP, WPA, MAC Filters). Disable any data encryption, set authentication to open; 2. Try other USB ports of your PC or verify that you have USB 2.0; 3. In your laptop if using XP, Control Panel, Network Connections, right click on Wireless Network Connection, Properties, in the General tab, click on Configure, Advanced, look for any auto selection of speed and replace it with manual or set to G or 54mbps, disable Power Save, fiddle with the different settings. it may be to your advantage to log down the original settings prior to modifications. 4. You have to play it by ear which combination will work out for you. In some instances, setting to a fix Channel (as in your AP/Router) also improves speed/quality. 5. If #1 makes you uncomfortable, perhaps at least using the MAC filter would give some semblance of security. 6. You likewise have to check if there are similar settings in your AP/Router as in #3. Hope this be of some idea. Pls post back how things turned up or should you require further information. Good luck and kind regards.
Posted on Sep 21, 2007
  • Louie  Role
    Louie Role Sep 21, 2007
    Hi again,
    Pls drop #2 as it does not apply to your situation.
    Cheers.
    Sergeant:
    Champion:
  • 293 Answers
First Contact your Internet Srevice Provider and ask them your same question. They may have some System Maintenance going on.
SOURCE:
Pls tell me the user limit for this router
NETGEAR G54 Wireless Router provides high-speed Internet connection and upto 54Mbps (IEEE Standard 802.11g specifications). Generally, it can handle multiple users but the bandwidth is sort of divided amongst the users. So, if there are 5 users, each would get roughly about 10Mbps at an average if all the users are logged-in and require data.
Hence, it is suggested to have minimum users to get better speeds per user
Hope this answers your question!
CreativeTECH
Nov 26, 2010 | NetGear WGR614 Wireless Router
My network card is only allowing 54mbps , I have 1.5gig dsl with a 300mbps router Do i need a new network card the driver is updated to last update
Your wireless network card is more than sufficient to handle the bandwidth provided by your DSL connection. A "1.5" DSL connection refers to a 1.5Mbps DSL line. Your network card is an 802.11G network card. Simply put, your network card will only run at a maximum of 54Mbps, far short of your 802.11N router's maximum speed, but provides more than enough room for the bandwidth provided by your Internet Service Provider. Gigabit connections (connections with speeds measured in 'Gbps') are almost exclusively for private networks or corporate networks with Fiber Optic connections.
In layman's terms, you can get a newer network card for your computer that will improve the speeds between your laptop and any other computers on your network, but as long as your network card is supported by any modern operating system, odds are it is able to transfer data fast enough to keep up with your DSL connection
Nov 25, 2010 | Toshiba PA3235U-3BTM Network Adapter
TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC): signal strength 85% green but tx rate 11 instead o...
Im sorry but you will never get 54 on your card toughs are theoretical maximum speeds and I have never seen a system actually achieve them the actual speeds received by wireless devices are actually much lower and 11 is a normal speed wile running over wireless. Im sure this isnt what you wanted to here and I am sorry but it pretty much comes down to manufactures lieing by telling you it goes to speeds that can never be reached.
I hope this helped.
Thank you,
Norse
May 16, 2010 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
Hello and thanks a lot for your time. I have a belkin N wireless router and it is about a year old, give or take. My connection speed to my laptop sits at around 24mbps. It used to run @ 54mbps. Youtube...
Streaming online Video on Wireless connection take a lot of Bandwidth and if the Wireless settings on the router are not proper then the connection dropping issue is tend to happen, check if you have the latest firmware on the Router or not and also try to download some large file, not movies and then check the connection speed, if its near to your satisfaction then we have to check the ping request to the youtube.com for the average lag and packet lost in the communication.
Mar 17, 2010 | Belkin (F5D8231-4) Wireless Router...
Problem with Pre n Router
54mbps is what the Belkin routers wireless signal transmits at! This cannot be altered and is working correctly regardless of other wireless card speeds.
Jul 10, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Wireless router dissconnects
Upgrade the firmwire you will find-it on www.trendnet.com
Mar 14, 2008 | Trendware TRENDnet TEW-432BRP Cable/DSL...
Trying to get a laptop on aol
What is your ISP? What kind of modem have they supplied?
Do you get a connection when using a wire?
Feb 11, 2008 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
Driver for a trendnet wireless card
you didn't specify the version number. Find your version here and select the download for your card. Hope this helps you. Please let me know!!
http://www.trendnet.com/downloads/info/tew-421pc.htm
Oct 28, 2007 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
NetGear WGR614 Wireless Router Logo
61 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
