Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis Starts and stops
Hi, we have a dryer that doesn't seem to get the chance to heat up before it turns off. It starts up right away, then stops, then starts....etc. I'm pretty sure the heat is working, the "red button" hasn't been tripped and I've washed the lint filter. Help?
Thanks
  • Bryan C May 13, 2009
    Bosch Axxis starts and stops and starts and stops and never gets hot enough to dry a load of towels
I have the same problem - did you ever find out if it is normal? a power saving option? mine dries fine, but does cut in and out continually. always has done this since new.
Posted on Mar 09, 2010
  • 21 Answers
Bosch dryer wta3510 cuts off & on &not blowing air out
Posted on Jul 10, 2009
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Posted on Apr 21, 2009
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
Dec 11, 2013 | Bosch Axxis WTA4400 Dryers
Tumble stops cycle when drying. its starts to dry but stops after a short while leaving the clothes still wet,after restarting several times the cothes dry
use multi meter and check moister sensor, cycling and hi limit thermostat lastly if it runs about 25 minutes then stops and need about an hour b4 it will start agin? u have bad motor windings
Nov 08, 2011 | Bosch Axxis WTL 5400 Dryer
Hello, I have a Bosch Axxis electric dryer that when i turn it on and hit the start button the light comes on telling me that the unit has started but it is not spinning. Also there is not any heat being...
Hi, Welcome to FixYa. If you turn the drum by hand do you feel any airflow out the back ? (you need to undo the vent hose too) This will tell you if the belt is broke. Let me know and we can go forward from there. Regards, Macmarkus :)
Mar 21, 2011 | Bosch Axxis WTA 3510 Electric Dryer
I'm using a Bosch Axxis dryer for the first time. The dryer seems to run for a minute, cut out for a minute, run again, cut out again etc. Is this normal? I'm renting this place for a month and there are...
Werlcome to FixYa.
That is indeed perfectly normal. It is actually changing direction each time it stops and starts. That`s how those particular Bosch operate.
On another note, if you operate the unit on the "auto dry" cycles without enough items or extremely light weight materials in it, the dryer will stop since it cannot "sense" the garments.
Otherwise it`s all good !
Good luck.
Thank you for choosing FixYa today. Please take a moment to rate the info provided here today.
Regards,
Macmarkus :)
Aug 27, 2010 | Dryers
Bosch Axxis electric dryer, 3 years old, dryer drum won't turn
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Bosch Axxis Dryer won'r heat
hi there what u need to check is the thermostats and the heater element which are at the back take the back panel of should be the small 1 and not the complete back panel right once uve got it of there u should see the stats and element now 1 easy way to check the element is with a cord with a plug on 1 end now with the wire at the other end place the live wire and the neutral wire on each of the prongs make sure they dont touch now hold the wire by the insulated part and turn on the power if it starts to glow then your heater element is ok and u should change the stats if it doesnt then your element is faulty m8
Dec 12, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
1,225 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
