Question about GE Nautilus 24" Built-in Dishwasher
Food residue on all dishes
My jdb1080aws jenn air dishwasher is leaving food residue on the dishes. Not the original food that was on them, but all glasses and plates have small food particles on them and the tub of the dishwasher has gunk too. Is there something that needs to be cleaned or unclogged? I cannot see a solution that is visible and easy.
Thanks. I have a very similar problem, but worse! My granddaughter, who is 10 years old, loaded the dishwasher and put a bowl that had been used to mix cornbread in the dishwasher without rinsing it, now EVERYTHING comes out with cornmeal on it! HELP!
The filter systems on the Maytag line of dishwashers which includes Jenn Air is very fine. In most causes the pump needs to be torn down and washed in a sink and a shop vac is also a great tool I use to clean the rest of the pump out that will actually stay in the dishwasher. The spray arms also need to be cleaned in the sink. Check your drain line under your sink as well and make sure that the drain line coming from the dishwasher has a high arch or bend that is higher than the base of the sink. This will prevent sink water from backing up in the dishwasher which can be nasty. Also make sure to run your hot water to the sink before starting a cycle to assure hot fills and the water temp. is best if set at 130 degrees on your water heater instead of 120 or 125 degrees. I hope this is helpful. This kind of problem can be agrivating to solve at times. Scott (North Caolina)
Posted on Apr 21, 2009
My Jenn- Air dishwasher (2 years old) used to clean great but now it is leaving a white film on the dishes and there is often residue left in the glasses as if it is rinsing with the dirty water. I can't...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 20, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
My Jenn-Air dishwasher, Model #JDB1100AWW, is now not cleaning the dishes well. We have had it for approximately 5 years and up to the last several weeks, it has worked well. Now, however, after the load...
heatman101
Oct 18, 2010 | Jenn-Air 24 in. JDB1100AW Built-in...
Soap (?) residue on dishes; also not getting them clean--food on
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
How do i hook up the ground wire on jenn air dishwasher model jdb1080aws
Attach the green ground wire to the frame of the device ... there should be a green screw close by the place you hook up the power.
Jun 13, 2010 | Jenn-Air 24 in. JDB1080AWS Built-in...
2 year old dishwasher. Dishes not getting clean. More residue
heatman101
Jun 03, 2010 | Jenn-Air JDB1105AW Built-in Dishwasher
I have a Jenn-Air Dishwasher and it is leaving small pieces of food on my dishes on the top and bottom rack
There are various reasons for this incomplete wash. Please find the possible troubleshooting steps in the bellow mentioned article:
http://www.partselect.com/dishwasher+dishes-not-clean+repair.htm
Thanks
May 28, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
2002 Jenn Aire used to wash and rinse beautiful, now doesn't rinse properly leaving detergent film on everything. Using Cascade Liquid which always worked fine before. Glasses are new so it isn't mineral...
Reduce detergent quantity. Check the rinse aid dispenser and fill if required..
Finally check your inlet water free flow to the machine. If the strainer is blocked clean the part.
May 21, 2010 | Jenn-Air 24 in. JDB1080AWS Built-in...
Not cleaning dishes well any more
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
54dyhjh
May 08, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
It is not cleaning dishes, it leaves food residue on dishes and deposits small bits to other dishes especially on glasses.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Jul 15, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Jenn-Air (Maytag) Dishwasher Leaves Film on Everything
Make sure you are using rinse aid like jet dry. All newwer dishwasher are made to only work properly with this in it.
Apr 23, 2008 | Jenn-Air 24 in. JDB1080AWS Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
299 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
