My bios detects my hdd on my del dimension but while installing XP, it does not detect any hard disk
  • gunninfo
    gunninfo May 11, 2010
    maybe a partitioning table is not formatted correctly. Are you able to reformat the drive? Where in the installation do you get stuck?
  • 29 Answers
U can use the low-format to format all the partitions
Posted on Apr 21, 2009
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
My Toshiba mk4058gsx HDD is not detecting
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 20, 2011 | Toshiba (MK4058GSX) 400 GB SATA Hard Drive
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Aug 12, 2011 | HP Compaq 6720s Notebook
If I try to start my acer aspire 532 H netbook only : a disk read error occurred" and Press ctrl+alt+del to restart ist show, but nothing happens, when i did it. what can i do?
- a "disk read error occur pertains to your hard drive
- try going to BIOS and check if the HDD is detected on system information
- if the HDD is detected, reset BIOS to default
- if it's not detected then you have a faulty HDD
Jul 02, 2011 | Acer Aspire One 532h2298 Netbook
I can't install Window Xp sp 2 in My Compaq CQ45 .If i stall Xp sp 2 ,it can't found HDD..
Restart your PC and go into BIOS Setup. For some computers BIOS setup keys are F2 and for others its Del key. If you are not sure which key takes your computer to BIOS setup. Start pressing F2 and Del keys alternatively immediately after you restart your machine. Make sure that your HDD (Hard disk Drive) is detected. If its not detected and appearing in the BIOS setup than most probably you have to open your hardware which is not recommended if you are a beginner. There can be a number of reasons like loose wiring and bad jumper settings on the hard disk id the disk is IDE.
May 05, 2011 | Computers & Internet
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
Could not detect HDD on my Asus P4B-M Motherboard
hi,
try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
Dec 22, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Hard disk drive not detected
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
