Question about Plumbing
I have a Coralais pull-out spray kitchen faucet model k-15160. Today it began leaking considerably from beneath the lever handle.
  • Anonymous May 05, 2009
    Leaking just below the handle, of the 15160 faucet. Pulled out valve spacer and temp limit stop, they look good. faucet 1 year old.
    Problem Solver:
  • 11 Answers
If it is fairly new then it could be repaired but if not then replace it. call a plumber.
Posted on May 07, 2009
How do you remove the lever of a kitchen kohler clairette faucet, it seems to be stuck
On the front of the faucet handle, there is a small plastic cover with an emblem on it. Gently pry it off with a sharp knife blade. Next you will notice a small "allen" screw head. Remove it by turning it counter clockwise until it's loose. (lefty loosie - righty tighty) Lift the handle straight up to remove.
Jun 23, 2014 | Kohler K-15160-7 Coralais single-control...
Where can I get a new valve cartridge for our Kohler Coralais R15160-CP faucet? It keeps flowing more slowly and I have cleaned all the filters in the pull out head, etc. The dishwasher on the same line...
Most cartridge's are specific to their faucet and need to be ordered from the manufacturer. Home Depot or another place like that, that carries Kohler plumbing supplies should be able to get one for you and may even have one in stock. Good luck.
Oct 17, 2013 | Kohler K-15160-7 Coralais single-control...
Kohler Coralais
Check under the sink to be sure the weight on the hose isn't resting on something, preventing it from retracting fully into the base. Also check to see if the weight might be in the wrong spot on the hose and not pulling the faucet back into the base properly.
Aug 30, 2012 | Kohler K-15160-7 Coralais single-control...
Kohler - Coralais Pull-Out Spray Kitchen Faucet
te leak most likely is the cartridge you need to take the handle off and there will be a lock nut under where the handle was, turn the water supply off and remove the nut the cartridge will pull staight out, cartridges can't be repaired they need to be replaced. Watch out because some cartridges cost more than what the tap is worth
Jul 12, 2010 | Kohler K-15160-7 Coralais single-control...
Kohler Coralais K 15160 The body has a machined hole in the back, about the diameter of a toothpick. It has begun to leak water when the faucet is turned on, however this occurs once in awhile.
The front of the handle has a plastic button which can be removed with your thumb nail or tooth pick. Once the button is removed use a 1/8 allen wrench to remove the handle. Remove the decretive sleeve to access the top of the valve. Tighten the valve stem nut and reassemble. It the problem persists you may need a new valve or rubber seal. The best thing about Kohler is they offer a lifetime no leak warranty. I personally will buy Kohler faucets and toilets because of the quality and warranty. Delta has some hi end products but the support and warranty policies will make you never want to service a Delta product again. So if the faucet still leaks just call 1-800-456-4537, and they will send you a new faucet or parts.
Jun 24, 2010 | Kohler K-15160-7 Coralais single-control...
Water volume slowed down
Sounds like you may possibly have some sediments in the screen on the spray head. When you pull the head out you can disconnect it from the flex supply line and see if the water pressure is okay with out the head connected. This will either confirm it is in the spray head or valve body.
Mar 24, 2010 | Kohler K-15160-7 Coralais single-control...
K-15160 Kohler faucet switch to change single stream of water to spray is stuck. It will not return to a single large spray. How do I fix this?
they get gunked up with grease and junk, and or mineral deposits from well water---unscrew the aerator housing(underside of rounded pullout part) inspect and clean all part making sure there are no cracks in plastic junk used today...also noting correct placement of parts
Mar 13, 2010 | Kohler Model 15160L: Coralais®...
Misaligned lever on Kohler kitchen faucet
There are two possible things to look at.
Because you say "misaligned" and "frozen" it could be the handle is not set to the correct position.
There is a set screw holding the handle in place. It is a hex key I believe on that tap. Loosen the set screw and lift the handle off. move to the correct neutral position and set the screw.
If this does not do it and you are getting nothing but hot. The ceramic ball and washers could be stuck or broken. While the handle is off remove and inspect them. They should move freely in the socket. Replace or repair if necessary. Just take them to a plumbing store they are common parts.
Hope this helps. Please rate the answer if it helped you.
Mar 10, 2010 | Kohler Model 15160L: Coralais®...
I have poor water pressure from the faucet, hot and cold, in a single handle faucet
could be a number of things.
most mixer taps have flexible braided inlet hose's make shure there not kinked.
also there may be built pressure reducing valves,usually removerable,a plumbers job really.
is there servive valves on hot and cold if so make shure there fully on.good luck ,any qs ask
Aug 09, 2009 | Kohler K-15160-7 Coralais single-control...
The pullout spout leaks
pull out the spray part and tighten the nut around the hose or take it loose and replace the washer
Jun 28, 2009 | Kohler K-15160-7 Coralais single-control...
Plumbing Logo
82 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
