Question about Hifonics BX1500D Car Audio Amplifier
The amp burnt up on the inside can i send it to the manufacturer and have them fix it
    Genius:
  • 1,066 Answers
Yes of course you can...however, it may be less expensive to just buy a replacement.  And find out what caused the first amp to fail.
Posted on Apr 20, 2009
Who fixes technical pro amps
All these Pro Amps are highly Modular in design internally - the Electronics internally are Modules interconnected - if you are an Electronics Engineer you can order the Module burnt or damaged and fix it yourself - BUT DO NOT TRY THIS IF YOU ARE NOT EXPERIENCED . When bridging outputs always remember to match the Specified Impedance of the Speakers by the manufacturer.
Jun 13, 2015 | Technical Pro 4200W 2-Channel Power...
I have a a435hcq with the flames on it and one of the screws fell out and im wondering how i can get it fix and what will th cost be
Don,t waste your money on getting it repaired, Minimuin cost is from $150 end up, depending on what is wrong with it, You can buy a decent use amp for less .
Nov 11, 2012 | AudioBahn A435HCQ Car Audio Amplifier
I just got this amp and something burnt up in it how do I fix it?
you probably burnt a transistor (power supply) thats what happened to my amp if you take the cover off the bottom you can see the circuit board and there will be these little black things with three legs on them, they will probably be melted and burn marks
you will have to send it in for repairs unless you can find a shop that repairs amplifiers around you
hope this helps!!!
Feb 25, 2011 | Pioneer GM-5000T Car Audio Amplifier
Where does the spring clip onto for a simpson ezi loader 5kg clothes dryer
Hi, I too have one of these dryers & have also found a spring, along with alot of fluff, some staples, & remains of the rear seal inside the dryer. must be a manufacturing fault by the looks of things, the spring was bent & twisted & must hold the seal in place. I would say it will need to go to the repair people for replacement. also note the fluff (remains of the seal) had an area where it had burnt from the heating element & could cause a fire.
Feb 17, 2011 | Dryers
My amp will not turn on i think its burnt how would i fix that
Using a multimeter, check the power going to the amplifier for around 12 volts, and check the remote wire for anywhere from 3 to 12 volts. If power is getting to the amplifier and the remote wire is signalling the amp to turn on, check the fuse/s on the amplifier. If the fuse is not blown, have the amplifier checked out by a stereo shop or send it to the manufacturer for warranty repairs.
Jan 17, 2011 | MTX Car Audio & Video
Burnt out my Boss BR 1180 How do I repair?
this is a job for an advance electronic repair tech...try the manufacturer..next a tv repair shop..then an Audio Install shop...if that doesn't work out..i'll personally try to fix it..for lest than anyone else..its probably the tranformer output circuit overrun..that part of the board or component wil have to be replaced...good luck
Jun 16, 2009 | Boss Micro BR Digital Recorder
Microwave blowing fuses
Sanyo isn't that great of a manufacturer.. I had a microwave from them a few years back that did the same thing.. The wiring inside the microwave is shot.. if you were to open it up, you'd probably see some burnt wires from a short. If you use the microwave over a range, it may be because of grease build-up...
anyhow, its better that you invest in a new microwave, rather than fix it. It will be much more cost efficient
Jun 02, 2009 | Sanyo EM-U1000W Microwave Oven
500/1 amp turns on, but small ugly bass comes out speakers
Heat sink is jacked!!! Burned it out. Replace it or send it away to get fixed.... check the pricin on it sometimes cost alot almost as much as new amp....
Nov 04, 2008 | Jl Audio 500/1 Car Audio Amplifier
LCD light has gone out
You will need to send it back to the manufacturer for repair for this. No doubt the LCD backlight has either burnt out of has a bad soldier connection inside. This can also happen if the unit has been dropped.
Good Luck,
BB
Dec 12, 2007 | Memorex MC7101 Clock Radio
Hifonics BX1500D Car Audio Amplifier Logo
89 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
