Question about Rockford Fosgate Car Audio & Video
1 channel is out in my Rockford Fosgate P6002. One day everything is working and 2 weeks later the one channel went out. I have the amp hooked up with 2 12'' DVC T2 or T4 Eclipse Subwoofers, sorry not specific. I am runnig the system with a pioneer DEH-P80MP. I don't know how to trouble shoot and not familiar enough with the area to send it to someone yet. Please help!!!
  • 655 Answers
Hello jason_dil,
Having 1 channel go out is a common problem with audio systems. Unfortunately, since it can be caused by faults in the wiring, head unit, amp, or the speakers themselves, it is tedious to troubleshoot. Being tedious doesn't mean that it is difficult. You can do it with a little planning and organization.
Here's a link to www.caraudiohelp.com/help which has pages and pages of step-by-step troubleshooting. I recommend that you read up just a little and print out any of the guides you need.
What you want to do is eliminate what ISN'T causing the problem and isolate what is.
1) First, do a physical check of all the wiring. Make sure all connections are secure and tight and that there are no obvious cuts, tears, or breaks in the insulation. Check all fuses. Either replace them with known good fuses or remove and check with a meter. Check RCA's plugs on both ends. Remove and reseat each plug. Make sure the pin is not broken off inside.
2) Move on to the defective sub and it's wiring: See if it works on the other channel.
3) Check the head unit output: Reverse the channels of the RCA's and see if the problem switches to the other sub.
4) If everything checks out in 1-3 above, you've isolated the problem to the amp itself. It probably has a faulty component and will need to be repaired or replaced.
Hope this helps. If it does, please rate as "FixYa". Thanks!
Posted on Apr 21, 2009
How many peak watts is a rockford fosgate p500/2 amp...i belive it is the last gen...the one with the silver cover plates...thank u
Hello
Rockford Fosgate P500-2 is capable of delivering 125Watts to 2 channels @ of 4 Ohms speakers, and 250Watts to 2 channels @ of 2 Ohms speakers.
Dec 29, 2011 | Rockford Fosgate Car Audio & Video
How can I bridge my Rockford fosgate t1500-1bd
if ur amp has to channels then u hook up the + to the right side of the amp an the - up to the other side of the amp , make shore u turn down ur amp if u do so
Jul 12, 2011 | Rockford Fosgate T15001BDCP Car Amp
I have a old 2001 rockford fosgate 2 channel p5002 model in great condition just need to know how many watts is it and which subwoofers are compatible to this amp? thanks
Your amp is rated at 500 watts. Here is the break down of your wattage.
125x2 at 4 ohms
250x2 at 2 ohms
500x1 at bridged 4 ohms
When hooking up the amp make sure to use 4 gauge power and ground wire.
Jan 07, 2011 | Rockford Fosgate Punch P5002 Car Audio...
MY P6002 blows the fuses everytime I hook it up. Dont know why?
you probably have a shorted component(s) inside the amplifier.
Aug 10, 2010 | Rockford Fosgate Punch P6002 Car Audio...
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Amp fuses blowing and amp overheat
Does the amp heat up if you power it up with no speaker wires connected to the amplifier's speaker terminals?
Jul 17, 2009 | Rockford Fosgate Punch P5002 Car Audio...
I have a rockford fosgate p250.2 amp hooked up to two 12' subs but the amp is not powering on... instead the protect light is on and im not sure if its because its so cold outside... please help and thank...
Remove the load from the amplifier (subs) and the RCAs
Retry.
If the light stays on, there are internal problems with the amplifier, and it needs to be serviced.
If the amplifier works normally, attach the RCA's and power on again.
If it remains on, connect one sub, and then the other.
Your amplifier is a 2 channel amplifier rated at
60 Watt - 4 Ohm - 2 channel(s)
125 Watt - 2 Ohm - 2 channel(s)
250 Watt - 4 Ohm - 1 channel(s)
Your amplifier is not rated for a 2 ohm mono load.
If you have Single voicecoil subs wired in parallel, you have a 2 ohm mono load - your amplifier will eventually fail.
Jan 16, 2009 | Rockford Fosgate Punch P2502 Car Audio...
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate P4002
Yes they are ! And that means the DC is on the speaker and will for sure damage the speaker if it already hasent
Jun 15, 2007 | Rockford Fosgate Punch P4002 Car Audio...
Rockford 750X
Check your wiring, and if everything is fine you might have a blown or broken channel on your amp
May 22, 2007 | Rockford Fosgate Power 750X Car Audio...
Car Audio & Video Logo
110 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
