Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Propane Gas
Fuses keep blowing
What would make a fuse blow on a larrs pool heater?
  • poolgenie Apr 20, 2009
    Could it be a transformer?
    Problem Solver:
  • 4 Answers
Probably to much voltage going through i would see the maannual to see if there is any way to lower the power going through
Or your using a fuse which is to low and need to use a higher voltage fuse
if non of those i would call a technician
Posted on Apr 20, 2009
Hot tub keeps blowing fuses. Only happens when the heater is on, any ideas?
According to the description, it looks like too weak fuses, respectively too strong current when heater is on. Heaters generally consume high currents, and when motor and heater run together, the current (amperes) may be too strong for the fuses.
May 17, 2015 | Pool & Spa
My hot tub will not heat up and the one pump is running. I can not turn the lights on or adjust the controls
check the fuses if no heat sounds like the pump that isnt running is the recirculation pump (which heater is connected to) if fuses keep blowing try disconnecting the heater element maybe shorted
Mar 04, 2015 | Jacuzzi Pool & Spa
Had an FL4 error code and in-line fuses were blowing, replaced the R0367100 igniter (old one missing the tip) and fuses, but still blowing the 2 fuses and getting the 04 code.
make sure the wiring is correct then take fenwall off turn around to see if burned spot where ignitor wires go in sometimes the ignitor will take out the fenwall shorting it out so you will keep going through ignitors
Sep 15, 2014 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
Jandy heater fuse point error
if it keeps blowing fuses sounds like a shorted ignitor or fenwall
Jul 30, 2014 | Jandy Pool & Spa
Pool Heater Blows fuses
Post the model of the heater that you are using it on. Post the voltage that feeds the heater.
Jun 13, 2014 | Pool & Spa
Spa keeps blowing fuses
Get out the wiring diagram if you have one
Then start at the fuse that blows & follow that
circuit to the most logical thing that would cause
a problem,such as a failed motor,pump motor,solenoid,
etc & then do some testing with a volt meter,ohm meter
Sep 18, 2013 | Pool & Spa
Jandy Aqualink RSO301 keeps blowing fuse
Great discovery! You're welcome.
Could you please take a few and rate my assistance.
thanks...
Charlie
May 26, 2009 | Jandy AQUALINK RS TELELINK KIT
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Propane Gas  Logo
428 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
