I had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
We kept getting no channels as well. We had our cable box hooked to the TV with the cable that screws in to the antenna port.
Since we thought that the problem was with the "channel auto search" function, we switched to using the cable with red/yellow/white connectors to connect the TV and cable box. Now we have cable!
We only use the TV for cable, so we don't know whether we could get local channels through an antenna.
How do you use a vcr for a tuner?
Help! did the factory reset by accident now its saying no signal and no channels found i had it plugged into the cable straight from the wall no box or anything and it was working just fine tried to turn captions off and acidently factory reseted it. now it wont work!
I have the same problem... IT WAS WORKING FINE WITH BASIC CABLE PLUGGED RIGHT INTO IT, POWER WENT OUT AND NOW I GET "NO CHANNELS IN LIST" AND NO WAY TO ADD CHANNELS!
I am very techy person, and have tried EVERYTHING you can possibly do... believe me. A simple scan results in "signal not detected" error. NOTHING was moved, only the power went out?! WTF!
We've got this at work (BLACK Olevia 36 Inch I believe).
Please email us @ [email protected] THANKS!
Your televisions do not have a tuner, you need to use a VCR as a tuner.
Do a simple auto channel search and see if any channels are reconized
SOURCE: no channels on the list
Be sure that you are on the "Tuner" input, and that if you are using a converter box, that you have the set tuned to the single channel that the box puts out. (In the US, that's either 3 or 4.)...accordianman
I did a channel search on "Air" as well as "Cable" and the TV still won't recognize any channnels. It says there isn't a signal either.
purchased his TV from an auction with no manual or remote control. I need to find both. Also anything else that is needed. No signal sign comes on when I turn the TV on.
power on: no signal. How do I fix it?
I HAVE THE SAME PROBLEM. I PURCHASED AN OLEVIA LT32HVE 32 INCH AND WHEN I PUT THE TV ON IT SAYS NO SIGNAL. THEN I HAD SOMEONE LOOK AT IT AND TRIED A COUPLE OF THINGS AND NOW IT SAYS NO CHANNELS. WHAT DO I DO?
Says No chanels in list. Traying to reprogram, does not work. Help
no signal go to menu then picture then powerup then home then hit enter then hit menu four times till your out of menu mode
I did a channel search on "Air" as well as "Cable" and the TV won't recognize any channels. I used VCR as Tuner, repeated channel search on "Air" as well as "Cable" and the TV still
won't recognize any channels. Any other recommendations?
