Question about Microsoft Office Professional 2007 Full Version for PC
In Excel hitting tab jumps to next page
In Excel 2007,if I am in column a and hit the tab key instead of going to column b it jumps to the next page and brings me to column ''M''. How can I fix this. Thanks!
  • ccfnd girl Apr 22, 2009
    Sorry I was not clear, Excel was recently added to my machine every file new or old has this problem. Nobody else in the office is having this problem and I can find any information under help. Any further ideas would be greatly appreciated.
  • agentx1121 Apr 28, 2009
    I have the same problem, it happened after I opened up an old MS excel workspace file. Now it happens on all files, even new ones. This has to be a setting somewhere.
I solved my problem. go Tools -> options -> transition -> transition navigation keys. if this box is checked, clear it.
Posted on Apr 29, 2009
  • 122 Answers
Have you tried hitting enter instead of tab. If that doesn't work, let me know and i will play with it, I have not had that problem. You may have a formula set to go to column M, that takes some work to find it, you have to go cell by cell.
You can copy the spreadsheet without formulas and redo the wholething. That takes time, but sometimes is the least stressful solution.
Posted on Apr 22, 2009
  • Linda Goldsmith
    Linda Goldsmith Apr 23, 2009
    The only way I can create the same problem is to set a page break. If this is happening with a new copy of Excel, the blank must have a page break pre-set.
    If your computer is the only has the new copy, backup your files and try uninstalling Excel and reinstall.
    If everyone has the new copy, try emailing the files to someone else in the office and see if they have the same problem.
    If they do, check for a page break, if not, IT will have to be called.
  • Linda Goldsmith
    Your problem may be that column A is merged with columns b-n. The easiest way to check is change your allignment in column A to right allignment; if the text moves to column N; the change it back to left allignment, right click on that cell, choose alignment and cancel the merge, that should fix the problem.
Remove page breaks in excel
We would appreciate if you share with us your Excel version as well so that we can give you a more specific solution to your issue. In the meanwhile, you can refer to the following steps to delete a manually-inserted page break in Excel 2007, Excel 2010, or Excel 2013:
(Important: You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.)
1. Select the worksheet that you want to modify.
2. Go to "View" tab, then go to "Workbook Views" section, and click "Page Break Preview".
(Note: You can also click "Page Break Preview " on the status bar)
(Important: If you get the "Welcome to Page Break Preview" dialog box, click "OK". To avoid seeing this dialog box every time you go to "Page Break Preview" view, select "Do not show this dialog again" check box and click "OK".)
3. Now do one of the following:
a) To delete a vertical page break, select the column to the right of the page break that you want to delete.
b) To delete a horizontal page break, select the row below the page break that you want to delete.
(Note: You cannot remove automatic page breaks)
4. Go to "Page Layout", then go to "Page Setup" section, and click "Breaks"
5. Click "Remove Page Breaks"
(Important: You can also remove a page break by dragging it outside of the page break preview area {to the left or right for vertical page breaks, or up or down for horizontal page breaks}. If you cannot drag page breaks, make sure that the drag-and-drop feature is enabled. To check the status of your drag-and-drop feature, click office button , click "Excel Options" tab, click "Advanced", go to "Editing Options" and make sure you have checked the "Enable fill handle and cell drag-and-drop" option.)
To refer to a pictorial explanation of the above steps, you can refer to "Delete a manually inserted page-break" section on the following Microsoft Support Page:
http://office.microsoft.com/en-in/excel-help/remove-a-page-break-HA102576899.aspx?CTT=1
GuruAid.com
Jun 22, 2014 | Computers & Internet
My excel is starting right to left in window 7
The default worksheet direction in Excel 2007 or 2010 is Left-to-Right. To change a worksheet direction to Right-to-Left, follow these steps:
  1. In Excel Ribbon click on the Page Layout tab.
  2. In the Sheet Options group click Sheet Right-to-Left. The sheet direction will be changed. Column A will now be to the far right. Columns B, C, D.. etc. will follow to the left.
- See more at: http://www.exceldigest.com/myblog/2012/04/29/how-to-change-worksheet-direction-in-excel-2010-to-right-to-left/#sthash.lSG25YXq.dpuf
May 27, 2014 | Microsoft Excel 2010
Cursor is stuck in the middle of the page and will not move to the left side. The back space button or the shift left button do not respond?
You've probably "frozen" your pane. "Freeze Panes" is a feature which allows you to keep one or more left-hand columns or top rows visible while you scroll through your worksheet.
When you ac
You didn't say which version of Excel your're using, but in Excel 2007, you can either freeze the Row 1, Column A, or any number of rows and columns based on which cell is selected (i.e., where your cursor is) when you click on "Freeze Panes."
In Excel 2007*, the way to fix this would be to click on the "View" tab, then the "Freeze Panes" icon, which will give you several choices. Click on "Unfreeze Panes." There you go.
* The steps are similar in other versions.
Aug 27, 2013 | Microsoft Excel for PC
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
Hp laserjet 4250 prints 2 copies when using excel
Go into the print properties in Excel by clicking on Page Setup on the File menu, then hit Options. Next to "Copies," change it to "1" and hit OK.
Oct 08, 2009 | HP LaserJet 4250n Printer
Keyboard buttons differ in Excel than I am used to
I would suggest reinstalling the keyboard drivers.
Aug 09, 2009 | Microsoft Wireless Laser 4000 Mouse
Tab key on keyboard will not work for moving across columns excel
You need to go into options, open the transition box and un tick the "transitions navigations key" box... This same problem has been ignoring me... You can also fix the double clicking problem in here too... under "edit"
Feb 02, 2009 | Microsoft EXCEL 2004 for Mac
Printing 2003 excel documents with excel 2007 student edition
In the view tab make sure your page break preview is set correctly.
Aug 24, 2008 | Computers & Internet
Presario arrow key and return key problem
examine the keyboard for dirt caught under the keys, this maybe diffucult to spot. this is not going to be easy at first, as the problem may lie further and at a more difficult angle, check also for damage to the keyboard and try to find a mechanical solution before suspecting the drivers here, as this looks like it may just be something caught under the keys, or the keys being dragged down together rather than a major electronic foulup.if you find nothing, then suspect drivers. after that, try checking for programming errors.
May 21, 2008 | Compaq Keyboard
CSV file to Import correctly into Excel 2003
Rudils,
The key is to import the data and not open the file directly.
1. Open a Blank Workbook in Excel.
2. Data, Get External Data, Import Data. (Excel 2007 is Data, Get External Data, Data from Text)
3. Browse to your .csv file and Select "Import".
4. Import Wizard should appear.
5. Page 1 Select "Delimited"
6. Select the row which you want to start the import.
7. click "Next"
8. In the Delimiters, select "semicolon" and/or other delimiters you are using.
Note: The bottom half of the window will preview the way the data is to be imported.
9. click "Next"
10. highlight each column of your data in the window below. For each column you can specify "General", "Text", "Data", or "do not import column" using the radio buttons in the top left of the Wizard box. This is an optional step.
11. Click Finish.
I hope that helps. Please add a comment if it not clear.
kpenguin
Nov 22, 2007 | Microsoft Excel for PC
Microsoft Office Professional 2007 Full Version for PC Logo
791 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
