Need Reemplazar part. Where buy?
I need part # 7398202 (cilinder) of Photocopy Mita DC 1435 for send to Sud America (Ecuador) Luis Jurado lufejuri1@hotmail.com
  • 40 Answers
Go to https://www.gmsparts.com They should have all the parts you need. Good Luck.
Posted on Apr 20, 2009
What is c-30 mita 1435 copier
tienes que lubricar bien bien la barra de tranporte y checar el motor que mueve la trasnportacion
Sep 22, 2010 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Where can I purchase a Cleaning Kit for my Mita DC-1435?
Hello, Glen.
Here's a link for a cleaning blade:
http://74.125.113.132/search?q=cache:UtkZ_0m7QVwJ:www21.shopping.com/xPO-DRUM-Cleaning-Blade-73918030+Mita+DC-1435+%22maintenance+kit%22&cd=1&hl=en&ct=clnk&gl=us
And, here's a link for Kyocera-Mita maintenance kits, but the specific model is not listed. You'll need to contact them at 877.813.7201 or email info@worldclassink.com to see if there is a kit for your specific model:
http://www.worldclassink.com/Cheap-Kyocera-Mita-Maintenance-Kit-m43-ift6.html
Hope this helps.
Feb 11, 2010 | Kyocera Mita Office Equipment & Supplies
Kyocera mita dc-1460 need parts
You might try to contact a Kyocera-Mita or Copystar Dealer in your area. But I don't think anyone will have those parts.
Jul 29, 2009 | Office Equipment & Supplies
Print Light Won't Come On and Allow Print
The binder has a cover on the right hand side of the machine, you must have dislodged it. press in on it and it should be ok.
May 23, 2009 | Kyocera Mita Office Equipment & Supplies
Play Station 3 40gb- Blueray lens is not reading discs
This is the number one problem with the PS3 so it's very common.
If you're in Ecuador I'd recommend fixing it yourself.
You can find tutorials on youtube and you can get a replacement laser on ebay.
First thing you need to do is take the PS3 apart and figure out which laser you have.
There are only two kinds.
If the bottom of the blu-ray drive is shiny then you have the KES-410A
If it's the other kind then you need KES-400A.
There are tutorials all over youtube on how to replace them.
Let me know if you have any other questions.
Mar 04, 2009 | Sony PlayStation 3 40GB System
I need the paper tray (the one after printing for a Copystar cs-1435
You will have to call a CopyStar dealer or a Kyocera-Mita dealer to get that part.
Dec 09, 2008 | Copystar Office Equipment & Supplies
Problemas con el sistema de enfriamiento
Hola, mi recomendacion es antes que nada reemplazar el termostato para iniciar bajo control. el thermostat de mas Baja temp para zonas calidas. Despues de esto asegurar el termostato funciona y abre al llegar a los 90 grados o mitas de ahuja debe de verse circulacion en deposito de agua. En estos vehiculos es importante purgar el sistema por medio de un valvula /tubo loicalizada frente a motor. se afloja y sale aire. cerrar cuando ya no salga aire/vapor. Despues de esto se podran tomar mejores conclusions. Recomendacion nunca quitar termostato permanentemente ya que es necesario en tiempo de invierno/frio para calendar vehuiculo adecuadamente. FIN
Sep 26, 2017 | 1989 Pontiac Sunbird
Mita DC-1205 Copier
Open the front door... on the right is your toner. It is a cartridge that inserts long-ways (front to rear) into the machine, and should be white or ivory in color. DO NOT remove the old toner cartridge without having a replacement on hand. The new cartridge will have a plastic "cover" on it that assists in releasing the toner cartridge locking tab, and "seal" the old cartridge as you remove it from the copier. The cartridge opening is face down upon installation into the machine, and you may get some spillage if you remove it without the cover. DO NOT remove the new cartridges mylar seal until AFTER you install it in the machine!!! There should be a picture label inside the front cover showing how to replace the cartridge. And there is a pictorial diagram on each new toner cartridge box also detailing this.
Use only MITA DC 1205/1255/1415/1435/1455 toner, OEM #MTA37041013. Should run you about $12-$14 per cartridge retail, or cheaper if shopping around (I sell them for $11.99). Do not use copystar brand for the same equipment. Although it's the same toner, the shape of the cartridge is slightly altered, and may not "fit" into the machine. I forget how it goes, either Copystar will work in Mita, and not the other way around, or vice-versa. Either way, better safe than sorry.
Oct 24, 2007 | Office Equipment & Supplies
32 people viewed this question
k24674
jasbo
jasbo
