Question about Creative Labs Zen Touch MP3 Player
"locked" my zen V 1GB is locked in key lock i held the lock button down too long then it locked, now it wont turn on unless i unplug it form charging then 2 seconds later it turns off... how do i unlock it?
    President:
  • 4,402 Answers
insert pin in reset hole while holding down power button, then let go, select clean up, let it sit and do its business, then when done, reboot
Posted on Jan 21, 2008
SOURCE:
Key wouldn't turn on 2002 ford explorer b/c steering wheel seemed to be locked up.
This is common, if the wheel was turning at the time of the key being turn off it will put preasure on the wheel lock pin, this causes the lock to be diffuclt to turn, what happens is the steering wheel has a plate inside column, this plate has a lot of slots going around it, so when you turn the key off a pin comes up and goes into one of the slots that algin over it and if the wheel turns back the slot hits the pin with enough force to hold it, so when you turnn the key the linkage pulls the pin down bbut if its held the pin wont move and key wont turn unless you move the wheel which in turn moves the lock wheel away from pin, nothing is wrong its just something that happens,hope this helps.
Oct 31, 2010 | 2002 Ford Explorer
Wont turn on
you need a new battery for you zen
look on ebay.com
or do a search for creative labs zen vplus battery
on the inetrnet
May 25, 2009 | Creative Labs ZEN V Plus MP3 Player
Stuck on "lock"
this happened to me but i'm not sure it will work for you.. try to put the actual switch into lock mode (push it firmly into lock mode) then slowly push it back to the unlock mode.. if it doesnt work the first time try it a couple of more times. it worked for me..
Feb 24, 2009 | Creative Labs ZEN Vision:M Digital Media...
Locked
Have you tried to remove the battery. If not, try this remove battery, see if that works. If removing battery doesn't work you may have to reset your player. First remove battery again, but before you put it back on, slide or hold your power on button, keep holding it down then insert battery. The load-up screen should come on asking to reboot, cleanup , or reload firmware. Just reboot and see what haps
Feb 01, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
My Creative Zen has a white screen but syill plays music
http://www.youtube.com/watch?v=a8g0sh7pc54
1. Fully charge the unit
2. Get a song to play
3. Lock the device
4. Wait for black screen and leave it like that for 20 seconds
5. Hold the play/pause button down and move the side switch out of lock mode, then push all the way down (like you're turning it off) and release (back to middle position)
6. Release the play/pause button
Sep 19, 2008 | Creative Labs Zen Digital Media Player
Wont turn on
mine is SanDisk SDMX4-2048-A70 Sansa e250 2 GB MP3 Player with microSD Expansion Slot and it stopped working when i unplugged it from the pc before i started to download things but any ways u know how u can lock it well i have to push a button to start it. so i had it on lock and held the button down for like 20 sec's counting slow, then that didnt work so i put it back on lock and held it again for 20 sec's again and it worked!! it turned on then i had to unlock to turn it back on to use it again!!! yeah!!! so give that a try...
Sep 12, 2008 | SanDisk Sansa e250 MP3 Player
Mp4 ikasu
have you tried charging it, *******?
Mar 14, 2008 | Creative Labs ZEN V Plus MP3 Player
Lost instructions for creative zen stone 1gb
You can the full manual from here.
Scroll down & click AGREE (if you agree!)
Jan 08, 2008 | Creative Labs Zen Touch MP3 Player
My Creative Zen v wont turn on
make sure it isnt in lock mode, then try charging it. is the battery is in correctly? hope this helps :)
Oct 14, 2007 | Creative Labs Zen V MP3 Player
Creative Labs Zen Touch MP3 Player Logo
62 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
