No , you may not. According to your M B manual you may use up to 2GB of 200MHz, or 233MHz or 333MHz. Not the 400MHz.
what wil usually happen if you attempt to use the other is that the memoryt wil be too fast and the computer will hang or freeze.
The fastest speed that the motherboard you have takes is PC2700. BUT... if you stick that ram in with the PC2100, the speed will automatically adjust which makes it backwars compatible, so if you put that in WITH another 2100 ram, it will downgrade itself to the matching speed of 2100. But you have to have this other ram in for it to work... Be aware, you can still upgrade to PC2700 however...
Hope this helps!
Comments:
Apr 20, 2009
- I forgot to answer the question. You cannot use the ram by itself, but you can use it with another slower stick of ram. And i might be wrong, you never know, just stick the ram in and if it boots up correctly, than it worked! No harm will be done to the motherboard as long as the pin numbers are the same! :)
Apr 20, 2009
- Also, if it is a laptop, you cannot use 184 pin ram, that takes 200 pin ram, which is a much smaller chip.
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send
Machinery until you...
(More)
Machinery until you return to Dsna coude reset sharp ar-5316
I recently upgraded from Win XP to Win 7 in my digipos retail system and somehow my Epson Thermal...
(More)
I recently upgraded from Win XP to Win 7 in my digipos retail system and somehow my Epson Thermal TM-T88IV RECEIPT printer has refused to work. I have downloaded the recent drivers from Epson.com and the printer is registered in divice and printers section. But when one checks the hardware section in the printers Properties, there is no information it's just blank, The printer is connected thru COM1. It has refused to respond. What can be the matter ?
