Question about Dometic RM2852 Refrigerator
I have a Dometic model DM2864 in my 2006 CrossRoads. It has recently stopped cooling altogether. The gas burner heats up but no cooling. When switched to 120 VAC the check light does not come on nor does the automatic light. When switched on and off there is a one time click noise heard coming from the back of the refrigerator. ???
    Habit-Forming:
  • 62 Answers
It has a leak in the ammonia system check around the burner for a yellow residue
Posted on Jul 25, 2009
Dometic RM2611, Freezes fine, Refrig OK on AC, but warms up when on LP gas. Can I safely increase the orifice size from #53 to #58? Thinking that will increase the flame and produce more heat.
Check the gas regulator and the lines for particles of dirt. You have modified the refrigerator it is going to take some work to find what is wrong. Don't modify the orifice from what it calls for.
APPLIANCE 911
Aug 27, 2016 | Dometic Refrigerators
What is the roll over procedure for a dometic rv fridge?
The procedure that you are probably thinking of entailed turning the refrigerator upside down for 24 hours, then righting it and turning it on. Though doing this will not hurt the unit try checking these things first,
  • Door closing properly? Check the door gasket.
  • Overpacked refrigerator? The unit will have to work harder if the refrigerator is stuffed and results in higher cabinet temperatures. Arrange the food in the unit to allow for free air circulation.
  • Is the burner dirty, damaged or not properly located under the ue tube?
  • Is the burner jet clogged? is the flame " clean?"
  • Is the ue baf e inserted properly in the ue tube?
  • Is the LP gas pressure low at burner?
  • Is there proper air clearance behind and around the unit?
  • Check the tubing behind the unit, is it damaged ? leaking?
Aug 26, 2016 | Dometic Refrigerators
NDR 1062 Dometic Refrigerator
Not unless you unplug the thermistor from the circuit board and let it run for 24 hours. If it does not cool after that then your cooling unit is bad.
Dec 05, 2013 | Dometic NDR 1062 Refrigerator
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
Dometic Refrigerator Model RM 2820 Stopped working purchased 5-4-2004 . Tom Collins
Hi Tom,
If your fridge quit working altogether, check your DC fuses in the fuse box, as well as the back of the fridge under the black plastic cover (3 amp). Though the fridge uses LP and 120vac to cool, it is controlled by 12 volts.
Apr 30, 2010 | Dometic RM2620 Refrigerator
Dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Aug 22, 2009 | Refrigerators
I have dometic modle R M 2333. It will not cool when set to gas. But is ok on AC. Burner flame is good, gas flow is good.
If the unit has a good flame and is staying lit throughout the cycle of the fridge, then you probably have a bad cooling unit. Does is cool ok on Electric? If so, then there is another problem. You may have rust build up in the flue that is not allowing the heat from the gas to work correctly. Try taking a screwdriver and small claw hammer. Remove the cover from the burner assembly and place the head of the screwdriver on the flue just above the burner. Tap the screwdriver lightly with the hammer and see if rust falls. If so, continue to do this until it stops. You then need to blow out the burner and try the fridge again.
Hope this helps,
Jeff
Jul 07, 2009 | Dometic Refrigerators
Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
Jun 13, 2008 | Dometic RM2652 Refrigerator
Checking my furnace's ignition
Gas burners serve as the primary source of heat in a variety of home appliances: water heaters, gas dryers, and gas cooktops and ovens, and-of course-- furnaces and boilers. When the burner fails, most gas appliances are designed to stop working altogether to prevent a gas leak. As a rule, it's best to have gas burner problems fixed by your gas utility service person or a qualified heating technician, but there are a few steps you can take to avoid paying for a service call.
Jan 18, 2006 | Coleman 2 Burner Compact Gas 425F499G...
Dometic RM2852 Refrigerator Logo
129 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
