Question about Haier HP42BB 42 in. Plasma TV
Dead, No click, No LED, Nothing.
No Power, no LED.
When Service switch on PS turned to Auto, LED comes on, Unit sounds like working, Sound ok. But no Display. Completely Blank!!
Thank you.
  • wehr4cy Apr 27, 2009
    This is happening to me on my 19". What I'm wondering is what PS stands for? Did you get this fixed yet?
    Problem Solver:
  • 8 Answers
Problem was found to be in y sustain PCB.
Posted on Jan 11, 2010
  • 3 Answers
I was having the same problem and i called haier co. to ask what i could do and they said to order a new remote control so i did and i received it and i turned my tv with the new remote and pushed the tv/use button and finally worked thank god. i wasn't getting any response at all only blue screen.and no signal. maybe you could try it remote only 20.00.
Posted on Apr 23, 2009
Poineer deck amplifier dc-z74 relays click but set deck does not come on no display lights dead unit
Part of your PowerSupply is Frito.
Probably the +/- 15 volt rails, could be other.
Check inside power voltages, probably some regulators are gone.
Preferably get a tech unless you have the know-how and test equipment...
PEACE---
Feb 09, 2016 | Audio Players & Recorders
Samsung PS-42Q96HD
Please check whether the inverter is working and giving voltage to the display board. If not, this might require attention of a qualified service technician.
Jul 12, 2012 | Televison & Video
Sansui A-909 LED indicator(peak power meter)
Check you have 14 volts on pin 3 of the driver chip for the meter.
Apr 05, 2017 | Audio Players & Recorders
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
RCA 52" D52W20 ATC221 TV Problem
The FBT is dead.The buzzing sound mean there no high voltage is come to the CRT(tv tube).No burning,marks on the FBT doesn't mean it not dead.I change parts all the time with out burn marks on them.Trust me i replaced dozen of the FBT before.It make buzzing noise it dead.
Mar 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Furnace will not start. a/c seems to work ok. i
HI; I need more info. How old is the equipment. name brand of equipment. Also to answer Your question ...Yes the tstat wire goes into the furnace to make several connections then a seperate cable(brown) will follow Your freon lines out to the condensor.Also try removing the cover and have a good light. Get someone to turn on heat at tstat and watch for clicking sound.Sounds like You have a spark assist pilot system. When the sparking starts the pilot light should come on. Then once the pilot sensor feels the heat comming from pilot light it will allow the gas valve to come on...BE CAREFULL...I ASSUME NO RESPONSABILITY FOR YOUR ACTIONS...alpharome416 PS.usually there is nothing to worry about just keep Your space to begin with ok.
Feb 09, 2010 | Dometic Rooftop RV Air Conditioner
Polaroid FLM373b No power.
When the filter capacitors went out , the power supply will feed AC instead of DC into the circuit board and may have damaged other circuits. Do you get the 5vdc standby voltage? it should be on one of the power supply out put connector the minute the you plug in the TV, you must have this before go further.
Dec 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Haier HP42BB 42 in. Plasma TV Logo
250 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
