Question about Vehicle Parts & Accessories
Remote start issues with 93 acura legend l base 4 door
I went to have my remote start installed on my acura, but the installer said he could not get the engine to turn over. the ignition 1 and 2 come on and the dash lights light up but it does not crank. i have the factory alarm system installed on my car as well as this new aftermarket system i jus had put in. so i need to know if i need a remote start bypass module to get my car to start and if so what model do i look for. thanks in advance.
  • 22 Answers
Generally there are two types of factory ignition key security types one creates a circuit when you put and turn the key(these generally have a chrome nipple on them which creates the contact)and the other type is an approximity type(most common)if its the approximity type you can test this by trying to start the car(with the remote) and hold the ignition  key as close to the ignition barrel as possible, if this works let me know and i;ll pass on the next step.If not you may need a bypass module.please provide more details about the car and the alarm.(model etc)
Posted on Apr 21, 2009
I have a 1992 Acura legend. the battery died. i installed a new battery and it wont start. what vould be the problem?
Does it crank (turn over) and not start? Does it not crank? Try locking and unlocking the doors with the key.
Mar 15, 2013 | 1992 Acura Legend
My 1991 acura legend 2 doors wont start and it wont make any sounds.
I installed a Acura Main Relay and it has solved the problem of stalling and not starting...
Jun 04, 2012 | 1991 Acura Legend
I unlocked my door from outside reaching in and the alarm went off on my 91 acura legend. How do I disable it without a remote?
Hi if you make sure all the windows are up you can shut the doors and lock them using the key this should then reset the alarm then if you open the door using the key this should then turn the alarm off.
let me know what happens ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 01, 2010 | 1991 Acura Legend
93 acura legend radio battery went dead in car and now flashing security light how do i get radio to work again anim assuming it needs a code an how can i get code for free
I just bought my 3rd Acura Legend...but never encountered this problem. They removed my battery to place in another vehicle on the lot...and when they replaced my battery, the radio locked up and would not do anything. I called the Acura dealership in my area....have an appt for Monday, she said $51.00 to get code. I was reading on all the websites i could find about Acura radio codes...then i come accross one posting about an Acura Integra. It said her code was under her ashtray. I went out to my car...pulled my ashtray out. There was a white sticker with a 5 digit number first, and then an E number. I turned my radio on, entered 5 digit number...it BEEPED. I turned it off, and turned it back on...to the most WONDERFUL BOSE stereo system!! It worked ya'll!! I was so shocked!! It may not help everybody....but my Acura Legend 4Dr Sedan has MUSIC now!! So i thought i would pass it along...saved me FIFTY dollars!!
Jul 29, 2010 | 1992 Acura Legend
Acura legend wont start
Run hot wire from battery to coil to see lf that is your problem.
Jan 11, 2010 | 1993 Acura Legend
Connect (-) power up cable to my four windows acura legend 1192
havent a clue to be truthful,does the kit come with a wiring diagram ,i should imagine that their is a central block with 4 outlets ,one for each window that connects to teh earth side of the window winder motor.if you have a diagram with instructions then i could tell you more sorry
Oct 24, 2009 | 1992 Acura Legend
My 93 acura legend wont start. Ticking sound??
That sounds like a dead battery. The ticking sound is the relay (a type of switch) which enables power to the starter motor when you turn the key. If the battery is weak, the relay will click, but there is not enough power to turn the starter motor.
Oct 07, 2009 | 1993 Acura Legend
94 Acura Legend-battery change no power to car only blarring horn
if you set off the alarm you have to use the remote control to stop it. some cars you cycle the passenger door twice and it will stop.
make sure the polarity is proper.
May 13, 2009 | 1994 Acura Legend
'93 acura legend sometime will not start, or will start and cut off in a couple of seconds. Wait a while and it starts up. The wait time varies.
My 93 legend starts up when i turn the key, but sometimes when i release the key the car will cut off.
I had the fuel pump replaced some weeks ago thinking that was the problem but now its doing it again. Any solutions will be much appreciated.
Oct 07, 2008 | 1993 Acura Legend
Replaced alternator now won't start
hello first check your fuse panel inside and under hood test all with test light if all fuses are good trace main power wire from back of alternator for a burnt fusible link i think its just a snapped fuse when installing new alternator the pos wire on back might have touch the bracket grounded snapped the fuse look good at the fuses goodluck
Sep 18, 2008 | 1994 Acura Legend
Vehicle Parts & Accessories Logo
240 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
