Question about Zanussi ZX56 / 4 Bottom Freezer Refrigerator
Zanussi zfc fridge freezer defrost timer problem
I suspect defrost timer is not working. what is the interval and duty of the defrost timer? is there an easy way to check timer operation?
HVACRH20
  • 237 Answers
SOURCE: fridge not working
Sounds like the refrigerant has leaked out of the system.
Posted on Dec 23, 2006
  • 27 Answers
SOURCE: Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Posted on Jun 30, 2009
BIKER T
  • 909 Answers
SOURCE: Zanussi Zx99/5SI fridge not chilling freezer Frozen over
Tell you what, first do a good 12 hour defrost and restart. Chances are you left the door ajar accidentally. (even though you say you never,) Most of the time there is the issue. If it continues after that, let me know and ill go through the defrost procedure (the cheap way)..
Posted on Sep 26, 2009
SOURCE: Zanussi ZFC 62/23 FF Fridge
zanussi f/freezer and my top door has dropped so the light in the fridge never goes off
Posted on Aug 08, 2010
imufo2
  • 3773 Answers
SOURCE: Zanussi freezone fridge freezer model number zfc
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 27, 2011
Where is the defrost timer in a Zanussi ZNB323W/ Electrolux/ ZNB323S fridge-freezer ? I can't find it?
The timer box is located in the compressor compartment to connect the timer to the electrical components which
defrost the battery evaporator (defrosting heater, thermal switches).
Dado
Sep 24, 2015 | Zanussi & Electrolux Fridge Freezer Handle...
Zanussi zrb324nwo fridge not chilling.freezer forming ice/frost
Sounds like a defrost component Dave Start by turning the defrost timer slowly clockwise until refrigerator stops running and then stop. Open freezer and look and feel. Is defrost beginning to melt the ice?
Fridge Freezer Timer
Genuine spare part for select models of Electrolux, Faure, Zanussi and Zoppas fridge freezers.
Defrost Thermostat
or the
Fridge Freezer Defrost Heater
If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 22, 2014 | Refrigerators
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Jun 30, 2009 | Refrigerators
Auto defrost is not working on my zanussi ice free fridge /freezer
You have a defrost problem. It means you have 3 parts that can be involve ( timer, defrost thermostat, element) most of the time it's the timer. Hope it was helpful. :)
Francois
Aug 25, 2008 | Freezers
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge not working
Jul 28, 2006 | Zanussi ZSS7 / 5W Compact Refrigerator
Zanussi ZX56 / 4 Bottom Freezer Refrigerator Logo
340 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
