Question about Audiovox ACC56 10-Disc CD Changer
Cd changer connections
I went to the swap and got a great deal on a prestige 10 disc changer. It is fm modulated and only has three wires to hook up from the controlls. One is black ( ground ) I know that much. The other two wires are a Green/white and an Orange/White. My question is where do these wires connect. I dont want to hook them up wrong even if the unit is working. If someone knows the connection for these wires I would really be thankful for the information. On The modulator it says Prestige P-165/P-185 Part # cdc8fm These are the only numbers on the unit and its built by Audiovox. Who ever helps me with this I want to say thanks for your time and Rock on!!!! Thanks to all you Guru's out there!!!
  • Thunderhorse Sep 22, 2007
    Benimur,
    Thanks for the help I appreciate your time. One question because I dont have the knowledge that you do. What do you mean by filter? Is this a solid state component that I wire into or is this a inductor / capacitor configuration that I need to buy at the stereo store? If this is a configuration, What values of inductance and capacitance do I need? Im trying not to over think this whole thing and make it more complicated than it needs to be, but Im sure you can appreciate my concerns. Nothing worse than poppin speakers and a bunch of static!
    Thanks again Bro!
    Thunderhorse......
    Brigadier General:
  • 6,966 Answers
Hi, On your Audiovox ACC56 10-Disc CD Changer with a Prestige P-165/P-185 FM Modulator, the wires: black - goes to the body (-) ground (as you correctly posted); Green/white - (with a small filter box) goes to the constant/always on 12V supply such as the + terminal of your battery Orange/White - should be connected to a switched power source such as the accessory terminal of your ignition switch or to the blue or yellow wire of your head unit or car stereo or whatever wire that will have 12V+ only when the head unit or car stereo is switched on. Hope this be of some help to you. Post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 21, 2007
  • Louie  Role
    Louie Role Sep 21, 2007
    Hi again,
    Alternatively, some installers just wire the Orange/White to a separate toggle switch with the other terminal of the switch going to the accessory terminal/wire of the ignition switch.
    Cheers.
  • Louie  Role
    Louie Role Sep 22, 2007
    Hi again Thunderhorse,
    There is no need to purchase a separate filter. Normally it is already built into the wiring (Green/white) before entering the RF Modulator box. In some instances this could be just a small coil (you are right about the inductor) covered by a hard plastic casing which can be cylindrical or rectangular or a heatshrink wrap. If not present unit should still work even without.
    Cheers.
SOURCE:
Cannot get any sound from fm. i have stations and aerial is ok just have sound on mw/lw any suggestions? gail
seems the fm tuner is blown, did you check antenna and connections? if ok then contact service for fm tuner problem.
regards
Feb 19, 2011 | JC Whitney SONY XPLOD 10-DISC CD/MP3...
Will the Audiovox SP-6cds hook to an Audiovox GM250 radio?
Yes - the radio has cd changer controllers.
The Changer is FM modulated - and the radio becomes the controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2010 | Audiovox SP6CDP 6-Disc CD Changer
I HAVE A KD MK88 JVC 12 DISC COMPACT DISC CHANGER FOR A CAR AND DON'T KNOW WHAT CHANNEL IT'S SUPPOSED TO BE ON TO GET IT TO WORK AND NOT SURE IF THERE ARE ANY POWER LIGHTS THAT ARE SUPPOSED TO BE ON
there are no lights on the changer. It has to be hooked up to a power wire(4-pins) and a controller that is mounted in/on the dashboard with a fm-modulator connected thru the radio antenna. You also need a jvc hand-held remote to turn it on/off and select the cds.
Sep 02, 2009 | JVC Car Audio & Video
Not getting sound from my cd changer with FM modulator
make sure you have the 2 audio cords running from the changer into the FM module
Mar 28, 2009 | Sony CDX-540RF 10-Disc CD Changer
I just bought a new car that has a xtreme sound 10 disc changer.
If the fm modulator is wired correctly, open door on changer and push small reset button at the bottom (unit must have power to changer).
Feb 24, 2009 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Need rf modulator for wms5100 stacker
Do you need the controller or the fm modulator? I have both.
Feb 11, 2009 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Wont play and keep ejecting
Make sure there is power to fm modulator. There are 2 reset buttons, one on controller and one inside the door of the changer, push both.
Nov 23, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
QWESTAR 10 DISC CD CHANGER WITH FM MODULATOR
connect the 12V IGN to the switched supply from the ignition and Back up to the unswitched supply straight from battery.
Jan 09, 2008 | Qwestar QC280 10-Disc CD Changer
My FM radio is not working after install ......
Hi , you may buy a portable fm antena adaptable in car body .
and install connect to antena plug and then good fm signal.
Nov 14, 2007 | Sony CDX-454RF 10-Disc CD Changer
Audiovox ACC56 10-Disc CD Changer Logo
266 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
