Question about Toshiba Televison & Video
Toshiba TV -- horizontal line
I hope someone can help me. I have a Toshiba TV model # 27 A10 made in 2000. It was working fine last night, and to day it has one horizontal line on the screen. I know this is not a satelite question, but I hope someone can help. It has volume and is changing channels. Thank you, Nick
  • 68 Answers
Sounds like you have feild colapse.take off the back and on the ciruit look for the horizontal and when you get it sue a screw driver and a mirror. put the mirror in front of the tv once you locate the horizontal plug the tv back on and look at the mirror and as soon as you turn the horizontal you will see the picture come back up to the correct size, if no good???? take it out and get a new one if you look on the side off the component you must get tthe same for safety, solder the new component in and try again
Posted on Apr 23, 2009
Toshiba TV picture has become single horizontal line in middle
this problem is caused by a faulty ir of cap's . First is c408 on the board it is a 100uf @ 35v i replaced with same uf and @ 50v , Second is a 2.2uf @250v and is c410 on the board replace both and your off to the races.
BEWARE OF HIGH VOLTAGE EVEN IF UNPLUGGED
BROUGHT TO YOU BY WWW.JCEWASTE.COM
Jul 22, 2010 | Toshiba 27AF43 27" TV
Screen doesnt work, sound works fine. It worked fine last night but wouldnt turn on this morning, why?
is the screen dark?, if is it, see if the TRC filament is light, if is it afirmative, turn a little clockwise the fly back knob that say SCREEN and watch if there is a horizontal line at midle of the tv screen. if is it, your problem is in the vertical stage.
Apr 10, 2010 | Sylvania 6427GG 27" TV
White horizontal line at top of picture
that is a capacitor arround 47 micro farads 25 volts or 2.2 /3./4.3 micro, replaced with 35 volts
in vertical circuit amp that is a 30 minutes job for a good tech
hope that will help you
have a nice day
Mar 17, 2010 | Toshiba 27A32 27" TV
Horizontal line in toshiba TVs
its the horizontal output IC
Feb 14, 2010 | Toshiba 28N33 28" TV
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
Ok, so know you own an LCD or Plazma set, visit the dumpster where your Toshiba is or perhaps your basement just for old times sake..
May 30, 2009 | Toshiba 32D46 32" TV
JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Apr 18, 2008 | Toshiba 42H81 42" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Toshiba television
the symptom is caused by a breakdown in power supply or the horizontal deflection circuits. have it check by a qualified service technician.
Jan 13, 2007 | Toshiba 27AF41 27" TV
TV has cloudy, blurry haze
The two symptoms are related and are associated with the high voltage transformer,since the problem developed overnight is going to the help of a qualified technician to diagnose the cause,if you are familiar with tv service look at the horizontal output transformer for signs of damage but be careful,there are dangerous voltages present.Or be safe and call for help.
Sep 25, 2006 | Toshiba 36HFX72 36" TV
Televison & Video Logo
254 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
