Question about Whirlpool Accubake RF362LXTS Electric Kitchen Range
Oven clicks to self cleans or f3, the door locks and food burns
My oven switched to autoclean from the 350 degrees last week when I wanted to bake a casserole. Today I went to bake a chicken on 350 degrees and after turning it on I got an F3 code and the door locked. Both meals were burn to a crisp! .
The oven is a Whirlpool Accubake System (Electric) Super Capacity 465. Will I need to buy a new oven or can it be repared?
My family is getting sick of fast foods!
  • Whirlpool Master
  • 3,361 Answers
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Posted on Apr 20, 2009
Whirlpool super capacity 465
Seems the thermostat is malfunctioning...thus when baking at 500..thats quite high...it keeps getting hotter past that point to where the oven thinks its in self cleaning mode. Also seems like the problem because when it cools down your allowed to use it again. There is no way to test it with an ohmmeter. Just remove and replace.
Nov 30, 2013 | Ovens
I went to clean my oven last night but my oven door wasn't latched. I started the cleaning and the word "door" flashed on the screen. Sure enough my door was not fully latched but the lock mechanism had...
HELLO,
HERE ARE SOLUTIONS ON HOW TO CLEAN THE OVEN OUR SELF
self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    Thanks.
    Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
    When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
    The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
    Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    How do I use the self cleaning functions - kitchenaid oven
    Please allow me to help you first with some background of self cleaning functions:
    Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
    If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
    Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
    You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
    Please check this website mentioned bellow which would give you a detailed method of how to perform it:
    http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
    Hope this would help you .
    God Bless.
    Jul 05, 2009 | KitchenAid Kitchen Ranges
    Whirlpool Electric Oven RBS305 overheats while baking, locks door
    The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
    Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
    If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
    Good luck
    Dec 18, 2008 | Kitchen Ranges
    My rf367 range gets so hot during the self cleaning cycle that the top of the range is to hot to touch and the fan on my otr microwave comes on.
    Normal operation. If in doubt place a high temp theromoter on range top to see if it exceeds 600-900 degrees
    The basic idea is "burn baby, burn!" Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
    Dec 14, 2008 | Whirlpool Kitchen Ranges
    GE Profile XL44 Spectra gas oven
    try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
    Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
    Whirlpool oven issue
    Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
    Whirlpool Accubake RF362LXTS Electric Kitchen Range Logo
    722 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
