Question about Ovens
Temperature settings have worn off.
My Inmensa oven is really old and the numbers of the temperature settings have worn off... how can i tell what i'm setting it to? Any pictures i can use as reference?
  • platinum_ice Apr 23, 2009
    thanks! the only problem is that i live in venezuela and i'm afraid my resources are rather limited... i'll check out the net though and see if i can find a picture of the knobs on a tappan range. cheers!
  • 1,869 Answers
This is a tappan range any tappan dealer can help you find the knobs
Posted on Apr 22, 2009
  • Jim Goldsmith
    Jim Goldsmith Apr 24, 2009
    no matter wher you live you can go to applianceparts.com or, e-bay and have your new knobs mailed to you good luck!
How Do I Calibrate An Old Maytag Oven
If the knob is consistently 25 degrees off from the indicated temperature the simplest and cheapest fix is to make a new indicator mark on the stove 25 degrees from the original.or some knobs have a glued on ring with the temperature numbers on them . Removing the ring and regluing it at the correct position could also work. Hope this helps.
Dec 31, 2013 | Ovens
Whirlpool oven keeps heading up
What is the model number of your unit?
Jun 26, 2013 | Ovens
Help - Knob positions on New World Debut single oven
Don't know how long ago you posted this but I have the same issues! The left hand dial deals with function and the fan oven setting is 2nd one. The grill setting is the furthest one round...I think. The right hand dial is temperature. 180 is at about half past. 200 is at about 40 mins past if you get my drift. All this I have kind of figured out through trial and error... Now I've just got to figure out how to change the light bulbs....
Aug 22, 2012 | Ovens
Can no longer read the temperatures around the oven knob
On the 720EF the numbers are recessed behind a small glass panel, so I think you are not talking about the same unit. If all else fails, I suggest you buy an oven thermometer from say Lakeland - they are about 4 to 5 pounds and are good. Run the oven, making a note where the marker is and see what temperature the thermometer gives.
Failing that, run the oven with the thermometer in all the time and experiment to see what the control; knob is pointing at for any given temperature.
Apr 10, 2010 | Stoves 720EF Electric Double Oven
I don't have the model number for this range but it's a very old magic chef gas oven. What I need is the oven temperature knob. The knob used to have all of the temperature numbers printed on it however...
If you go any hardware store (Lowe's, Home Depot) they have universal knob replacement kits. Take your old knob with you and ask for help from someone who looks like they know something (the old guy). Its so much cheaper this way, exact replacement knobs can run $20 or more each. Good luck!!
Jan 16, 2010 | Magic Chef 9122 Gas Single Oven
How to set specific temperature
you can use an oven thermometer to check the temp ranges
Apr 26, 2009 | Holman Ovens
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Ovens Logo
232 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
