Question about Nikon F65 35mm SLR Camera
Err message The camera is showing an ERR in the aperture area of the LCD area...I am not able to use the shutter button auto focus...Can someone suggest what to do?
  • Anonymous Jan 05, 2008
    i have the same problem that Err message blinking on the right side of the LCD pannel and view finder screen of my F65. Pl olve my problem. Is it due to low battery.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
If the error message is on the left hand side of your LCD monitor then your shutter is not coming on line and it might be the 'reset' switch in the back cover locking mechanism that needs replacing. If the error message is on the right hand side of the monitor then this is because the F - stop on your lens is not set to highest setting ( 16 or 22 ) . Set your lens to highest setting and check again to see if error ( FEE ? ) disapears.
Posted on Sep 23, 2007
SOURCE:
Nikon d80 camera shows err error, when shutter is pressed the amount of shots remaining, shows er07. shutter works, but no picture is taken. Bracketing sign is also on display and wont go off.l
failure of the aperture unit is the usual cause - usually the contacts for the phase switch have come loose from the gear. You can find info on this by searching for the problem on the internet, including how to repair it.
Apr 06, 2013 | Nikon D80 Digital Camera
I have a nikon d90,when i pressed shutter button ,it is giving err message then i press second time it is not giving err message but not taking the photo.
This is an indication that the camera is not "talking" to the lens correctly. When you press the shutter button, the camera tries to focus, set light levels, and then shoot the picture. If it can't focus or set F-stop and shutter speed, then it can't shoot the picture and gives you the error indication. SO
1. You need to make sure the lens is an automatic lens capable of working with the D90. 2. You can take the lens off and back onto the camera a few times in case its a dirty contact issue or just didn't seat correctly. 3. Set the D90 to manual and make sure you move the AF selector on the front to M. Then you would manually adjust all the settings. That should take the auto-coupling out of the picture (pun intended)
4. If it still shows error when in total manual mode, there may be something wrong in the camera itself. Before giving up, do a total system reset on the D90 (I assume you have the manual).
Nov 15, 2010 | Nikon Cameras
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Error blink in place of shutter indicator
I AM SAGHA REPAIRER FROM MUMBAI I THINK THERE ARE PLENTY OF REASONS SHOWING ERR ON TOP DISPLAY BUT IF ERR IS SHOWING JUST BY TOUCHING THE SHUTTER RELEASE BUTTON THEN THE MAIN BOARD IS DEFECTIVE.IF ANY MECHANICAL ACTION OCCURS AFTER PRESSING SHUTTER RELEASE BUTTON AND THEN ERR APPEARS THEN THE FAULT COULD BE OF SHUTTER & APERTURE BLOCK.I THINK ALL THESE SOLUTIONS ARE FOR EXPERTS AND NOT FOR GENERAL USERS IF ANYBODY FINDS THEM USEFUL LET ME KNOW & ALL THESE ARE BASED ON MY OBSERVATION ABOUT FAULTY CAMERAS.
May 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
"Err" appear in the viewfinder and LCD display
i have a Orite Mv 3115-Real Dv Mpeg4Vga resolution 30 FPS Digital Veidio Camera. no the problem that the battery of my camera down and i sent that with my friend to bay a new for me unfortunatly he miss that on travel so i need to fins a new battery for that
i hope sir you can healp me to find one and a charger too
Feb 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
My fuji finpix s1 will not pull up the menu, nor can I take any pictures however the automatic focus works, the function lcd lights up but it will not work either.
rdp19 did not mention the ERR msg.
I had the same problem, however after messing with it the ERR message is up.
If RDP19 gets this, did you get it fixed.  Where and what cost?
Jan 26, 2009 | Fuji FinePix S1 Pro Digital Camera
ERR message
unmount and remount the lens. Make sure you have the aperture ring on the lens set at the minimum f-stop number, ie f22, f32. There should be a small tab on the lens to lock the aperture ring in that position
Dec 27, 2007 | Nikon N80 35mm SLR Camera
Nikon D200 with Sigma 18-200 DC AF D lens
Yes, please turn off the camera when changing lens, make sure on the lens is on its full aperture if you are doing auto. if doest not work to make is test turn the camera on the manual mode and the lens too.
If your lens is new there should not be any problem, if you bought the lens used make sure all the points are clear not rusted. some time when lens fall of it breaks its points inside.
Dec 20, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D70 Err
Sounds like the shutter is sticking. This could be due to damage or just need cleaning. This probably means that you need to get the camera professionally serviced/fixed as shutters are extremely delicate.
Nov 09, 2007 | Nikon D70s Digital Camera with 18-200mm...
Nikon F65 35mm SLR Camera Logo
517 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
