Question about Refrigerators
Kenmore model 106.53644300 side by side does not cool
Kenmoore side by side does not cool condensor and evaporator fans operate bu compressor klicks on and about 30 to 60 secondsklicks off
  • Refrigerators Master
  • 3,361 Answers
First replace the compressor start relay. If that does not correct the problem you have a bad compressor.
Posted on Apr 20, 2009
Refrigerator not cooling.
No the evaporator fan not running has nothing to do with the compressor. I would suspect that you are freezing up over the evaporator because the fan is not running and when it ices up the air can not flow through properly therefore causing the refrigerator side to get warmer. Replace the fan and you should be fine. Take the back panel inside the freezer off and see if you are all iced up. If you bare then I would replace the fan . You also said the defrost heater did not come on. That will also cause a freeze up. Possible replacement of the defrost heater may be needed. Good Luck!
Jul 25, 2015 | Amana Refrigerators
Refrigerator running and not getting cold
you may hear the condensor fan in the rear area and evaporator fan in the freezer compartment,but the compressor is not running due to a bad ptc overload/relay on the compressor body,unplug the unit,then on the left side of the compressor in the lower back side is the ptc,unplug it off the compressor and get a replacement,this is what helps start and operate the compressor
Oct 25, 2012 | Kenmore Refrigerators
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
Jul 22, 2011 | Amana Heating & Cooling
Refereigerator Model GBE18JBRWW, bottom freezer Not cooling properly. I opened the condensor coil sections and noticed the frozen ice. Disconnected the refereigerator for few hours and the refereigerator...
You have a defrost system problem. The coils with the ice are the evaporator. If the fan is working inside either your defrost timer or defrost heater assembly has failed. you may want a tech for this
Jun 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator freezer does not cool below 70 degrees. I just relace the start relay and now the compressor runs but the condensor fan won't work unless i give it a little spin.
Lubricate the condensor fan with a parifin based oil like Union 76 turbine oil or "Zoom Spout" oiler. These fans are notorious for the bearings drying up on them.
Being careful.... touch the compressor copper lines. One should be very warm almost Hot to the touch.
Also with the unit unplugged..... note that there is a coolant drier with a small capillary tube coming out of one end. Tap the side of this by holding a hammer handle (wood) against it and hit it on the side with a screw driver handle.
Check to make sure the evaporator fan in the freezer compartment is also running when the compressor is on. Anytime the compressor is running BOTH fans must be running. If you can not get the condensor fan up to full speed you will note that the chassis around the door seal area will be quite warm almost hot to the touch and the unit will not be cooling properly. Just for troubleshooting.... direct a fan at the condensor coils and see if the freezer compartment gets cold and that the chassis around the door seals is just warm.
Note about compressors in general.... if you unplug a unit.. it must settle / stabilize for 15 - 20 minutes so that the compressor can restart. Any power off periods less than 15 mins will result in the compressor cycling via the thermal overload every 4 minutes or so... and it does not run for more than 40 seconds when the overload kicks off the PTC relay power.
If you never feel the copper line off of the side of the compressor get hot then the unit has lost coolant.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
ED2KVEXVL Whirlpool refridgerator - not cooling in refridgerator
Your freezer is not reaching the target temperature to produce ice - obviously your whole unit is not cooling properly - first thing to do is shut it off unplug it and remove the back panel from the freezer and look for ice buildup and overfrost on the evaporator - this is a classic symptom and will cause cooling problems - manually, using a hair dryer, melt the ice and frost from the evap until everything is cleared up and drips into the drain down the drip pan - once everything is cleared up put back the panel and turn everything on - allow a couple of hours for things to cool up - if it cools normally, then your problem relates to a faulty defrost system in which case you would need to have it serviced and replace one of the defrost timer components (control board, element, etc.)
Set one of these special refrigerator thermostats (not the mercury ones, but I use the round gauges) put one in freezer one in refrigerator and after couple of hours monitor the temps. Freezer should not be warmer than 10F - normally 0F, but optimal temps are -10F (and also if you want hard icecream) -10F allows faster recovery in case of outages. For refrigerator no warmer than 40F - you want optimal to be 34F.
You want to also make sure your evaporator fan motor is spinning and look for any door gasket leaks.
If, after checking your evaporator fan and coils for frost, and door gaskets and you notice your unit is not cooling properly and your compressor is running continuously without cycling off, then next step would be to check the condenser and clean the excess dust (which traps the heat) if your condensers are at the bottom and they are clean, then make sure the condenser fan at the back / bottom of your unit is running.
If all fails, then the last thing (rare) would be a sealed system leak, in which case you will need to get it serviced and it will cost you a lot of money.
If you notice your compressor cycling off before the target cooling temps, then raise your cooing knob at higher temps, if it works then your thermostat is out of calirbation.
If everything cools normally after you've defrosted manually then the problem relates to a defrost problem - in which case you will need to get it serviced and have the control board checked and defrost timer components.
If your freezer is cooling normally and not your refrigerator section, then check for any obstruction of the vents, door gaskets and if you have one, the damper flap not opening wide enough or at all to let cool air in, if applicable to your model.
best of luck.
Sep 20, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Kitcheraid KSRG22FKBL01 Refer
replace the compressor overload with part numper 4387535
can get it at www.apwagner.com
Jun 23, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore Refrgierator is not cooling enough
Is the frost on the entire surface of the evaporator or just a portion. If it is only frosting on a portion there is a possibility your system has developed a leak and has lost some of the charge. Or your compressor has lost its ability to pump the gas. A bad condenser fan motor overtaxes the compressor and can cause premature failure. If it is a bad compressor it may be time to replace the refrigerator. Replacing the compressor is an expensive job and the warranty is only one year on a replaced compressor.
May 31, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
