Question about E-Flite Blade 400 3D RTF Electric Mini Helicopter
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Cannot get blade 400 stable crashed it repaired it helicopter tail unstable unsure of correct servo settings
Dude is your swash plate levle if it is not it will cause your heli to drift
or if not go on youtube and reset your dx6i settings
Posted on Sep 29, 2009
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Posted on Jun 02, 2009
My sky Rover helicopter will not fly forward any suggestions
check the small fan at the back of the helicopter and its motor. This controls the tilt of the helicopter it it does not work the helicopter won't tilt down in the front and won't move forwards or backwards
May 16, 2017 | Sky Toys
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
My S031 when powered up floats backwards and drifts sideways, just put on new blades did not fix the problem can anyone help
Helicopters are not easy to fly, they are not naturally stable. New blades do not solve the problem, this can only be achieved by training and very delicate movements of the cyclic pitch control. I recommend to use a larger skid (broader) or some light device that enlarges the skid surface (to avoid tilting and damage). But be sure that a coaxial helicopter is easier to fly than any conventional model with just one main rotor and anti-torque tail rotor.
Jan 28, 2015 | Syma S031 Gyro 3 CH RC Helicopter Orange
Volitation helicopter just spins to the left on ground and will not lift off seems top blades are spinning much faster then bottom
If one blade is spinning faster than another, then the helicopter won't lift off. The first thing to check is the gears driving the blade shafts. It could be that one of the gears is not set properly, or there is something caught near the shaft. Pet hair can often wrap around the shaft and cause drag. If the gears appear to be in the correct positions, and meshing with the pinions (small gears) on the motors, and there is nothing wrapped around the shaft, such as hair, I would slowly increase power and see if both motors start spinning at the same time. If they don't, there could be a problem with the motor, or the controller board. If this is the case, it may be repairable, but might be just as cheap to replace the whole helicopter.
Hope this helps!
Aug 29, 2013 | xheli 9053 Outdoor Volitation Metal...
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
Throttle Problem
Hi
Your ESC is sensing an error. The error is either blade speed or a peripheral device - possibly servo or gyro. Sub the servos one by one. Check the blade tracking. Have you had any crashes lately? You should double check all the head assembly components.
Jun 02, 2010 | E-Flite Blade 400 3D RTF Electric Mini...
Tremendous machine vibration
Make sure the "connect buckle" is connect to the correct side, and not bent in the middle, it should be straight. If this doesn't help, new blades are sometimes different weights try to matching the weight of opposing blades you may even need to sticky tape a small weight underneath the blade to get them balance. Don't stick anything on to the top of the blade.
May 25, 2009 | Apache 3 Channel Micro Indoor Helicopter...
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
My helicopter won't fly, it just spins around.
The top rotar blades are not turning but are slipping every now and then.
Dec 30, 2008 | Air Hogs Havoc Heli Helicopters
E-Flite Blade 400 3D RTF Electric Mini Helicopter Logo
884 people viewed this question
Top E-Flite Toys Experts
ray gallant
Are you an E-Flite Toy Expert? Answer questions, earn points and help others
