Question about Epson Stylus CX4600 All-In-One InkJet Printer
Espson Stylus CX4600
When I attempt to change the ink cartridge the carrier always return to the orginal postion on the far right. This makes it physical impossible to remove the old cartridge.
    Brigadier General:
  • 6,966 Answers
Hi, Not that sure with your particular model, but pls how are you engaging the change ink cartridge mode, button on the printer or via the printer utility? If you are using the printer button, you may be double switching or the switch is bouncing. You may want to try using the Printer Utility function. Click on Start, Printer and Faxes, right click on your Epson CX4600, click on Properties, Printing Preferences, Maintenance, Ink Cartridge Replacement icon, Next, Next > follow on screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 21, 2007
Have an Epson NX200. Need to change ink cartridge but ink carrier will not position so I can open it.
usually you can move it manually with your hands .Turn off first your printer .once it turns off pull the carrier, pull the white tape gently to the center and just replace it ink cartridges there. Make sure its properly plug in .Once your done return the move the cartridge carrier manually from left to right 5x once your done you may now close the cover .(close it first ) And checked if its going to the center once you open the cover .
Hope it help thanks
May 26, 2011 | Epson Stylus NX200 Printer
Try removeing all the cartridges, start the printer do you get a error message code?
put them back and check the error and code again.
Thanks, waiting for your reply.
Jun 01, 2008 | Epson Stylus CX4600 All-In-One InkJet...
I have an Epson Stylus NX200 and need to change the ink. When I open the scanner lid the ink cartridges are on the far right and I cannot reach them in order to remove them. Turning the machine off and on...
You will need to press the STOP button for the cartridge carrier to move to
the ink change position.
Additional information can be found at Epson support page.
Click on link below and mouse to Remove and Install Catridges at bottom of web page.
Mar 10, 2011 | Epson Stylus NX200 Printer
My espson R200 won't print black even though it is full :s
ESP-son? EPSN-Sports-Online?
Use the EPSON software to run a "print-head-cleaning" cycle to try to "unclog" the path that the ink takes from the ink-cartridge, through the "jets" onto the paper.
Nov 17, 2010 | Epson Stylus Photo R200 InkJet Printer
I just replaced ink cartridges in epson cx4600 and now all pages are blank when printing
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Jun 27, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Can't change ink cart. EPSON STYLUS CX 4600
I may have tripped across a solution to the ink carrier that doesn't want to behave.
I turned the printer off. Then, while holding down the Ink button, I also pressed and held the On button- and kept holding them. Somewhere in documentation I read that this would kick off some process, but I didn't remember what. It didn't turn on right away, but after 4 or 5 seconds of holding the buttons down, started up, went through some motions, and lo and behold, it landed on the spot showing me my cyan cartridge was out. Pressed it again, and it went to the cartridge change position.
I had to think about it, because I was now faced with breaking open a cartridge package worth $35 that could go towards the price of a new printer, and the printer still may not work, but I went boldly forward and it seems to be working fine.
Nov 15, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Catridge won't go to right position
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Jun 12, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Ink OUt problem
Did you make a cartridge aligment and calibration when you replace them ????
Feb 12, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Printer reports always "out of ink"
The Stylus CX 4600 gets its jets clogged easily when you don't use it every day or so. Cycle through several times of cleaning the jets and printing the results, until it comes out right. I have had to do this as many as 6 times to get the test print to have no gaps, but eventually, it will always work if you clean them enough.
I have also had new cartridges report empty. I called the aftermarket source where I got them, and they had me return the cartidge for a free replacement. The replacement worked. Sometimes, paying 20% of the Epson cartridge price gets me junk cartridges.
Sep 23, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
May 05, 2006 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
