Question about SATO CX400 Thermal Label Printer
Physical alignment of lable holder lost
My printer's lable holder has shifted to its right side from its centre. kindly tell me how to solve it. if its requires to open printer how to open.
After priting more than 100stickers it jump, after four printing sticker.pls give me proper solution on my id shobhana_house@yahoo.co.in & also bottom side of sticker barcode no goes to second lable.
Posted on Feb 08, 2008
Somehow i got service manual from the net, I opened the printer and found that, the gear of the lable holder was slipped aside. and i fixed the problem.
Posted on Sep 27, 2007
  • 163 Answers
Pleasesir check its lock and screws for open it but take care
Posted on Sep 21, 2007
How do I reattach the encoder strip?
Should be a fixed mount on the left side of the carriage and a sprint mounted latch on the right. You will be able to tell if you have through the carriage properly if the strip runs straight through.
Oct 27, 2015 | HP OfficeJet V40 All-In-One InkJet Printer
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
How to service ink jetprinte
A generalised service would be to run a head clean, alignment, physically clean the printer inside and out. Also replace the cartridges. Some printers can be maniputlated with servicing software if you can get the right software for your printer. This allows you to reset counters, look at the printers overall use, that kind of thing.
Mar 26, 2014 | Office Equipment & Supplies
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
Having problerm with aligning cartridges the printer keeps telling me that the alignment failed. how can i fix this?
hello
that was the problem of that printer model it keeps telling but after you follow all the instructions still the same. Unplug the power outlet from the wall and at the back of the printer, leave it for some time and remove the cartridges and put it back again and power the printer sometim it solve the problem.
That problem is mechanical faulty of your printer
thanks
Mar 12, 2011 | HP OfficeJet 6110 All-In-One InkJet...
When my 2000 Villager shifts if kind dips or
That movement is called TORQUE STEER. One front wheel pulls harder than the other under acceleration, and as you say, its only noticeable at the first moment. A renewed front end shouldnt have that problem. maybe some steering or arm ball joints are loose, worn out (not replaced) or simply out of alignment. I advise that you take it for a new front end alignment, the technician will tell you about any part out of spec that will impair the alignment.
Nov 22, 2009 | 2000 Mercury Villager
Paper not feeding right
you need to take all of the paper out then fix the paper so it is all aligned then place the paper back into the paper holder still all aligned this should then prinbt properly
Jul 22, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Label by label empty
I think that the settings in your label printer driver are not the same as the physical label.
Say you have a 50 x 25mm label , then the settings in the printer driver must be the same, both in the "Properties" and the "Default" Tabs. Also if your printer has a calibration routine, then run this first.
Jan 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Left side margin is fading out right side margin is printing correctly
First try to align the printer head either with software or at the printer control panel. If that one couldn't solve the problem then you may have the encoder strip dirty at left side. It is not easy to access the encoder strip, sent it to workshop.
May 12, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
SATO CX400 Thermal Label Printer Logo
214 people viewed this question
Top SATO Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Argospete
Argospete
 steve
steve
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
