Question about Sanyo DS20930 20" TV
Power on problem, very strange.
I just want to tell everyone first, that I am not very technically knowledgeable about televisions. I have a Sanyo 20" Flat Screen TV. I was watching my TV with no problems about 2 hours ago (from this time.) I turned it off, left for about an hour, and to my surprise, it sort of doesn't work. When I attempt to turn the TV on, it will turn on for about 3 seconds and it will shut off again. I have tried moving the TV's power to different sources a few times. It still does it. Now the strange thing is that when I attempt to turn the TV on in between unplugging and plugging it back in, I can only get three attempts to turn it on out of it. The 4th time you try to turn it on with the remote/power button, there is no response. Then I unplug it for about 3 minutes, plug it back in, and it will repeat the same thing (turning on only 3 times and turning itself off.) Like I said, I don't want to try open up my TV (cathode ray tubes can store an immense amount of electricity even when its unplugged, like a CRT computer monitor. I am no professional. I want to know if I can fix this myself or if I have to pay big bucks to get it fixed and rather just toss this one) Thank you for any help! It is appreciated!
  • Kaiga Sep 21, 2007
    By the way, I have verified that the TV is a DS20930 20". I found and downloaded the technical service manual. I have no idea what any of that stuff is. I can put it up on a file server if anyone would like to download it.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
I want to know if I can fix this myself or if I have to pay big bucks to get it fixed and rather just toss this one) as you are not tech person so you can not do it. it is not a big problem there might be problem in power supply. you need not have to big bucks.
Posted on Sep 21, 2007
Sanyo 1LG4B10Y04800 how do I find out what board my television takes this is the Power Board number
Assuming you are observing all ESD & Safety precautions...
The absolute best way to tell what pack you need is to LOOK at your old pack...
Go to a parts supplier...
Put in your make = SANYO
MODEL = something like "DP42841"
that ought to be a Sanyo Lcd tv ...
such as ... shopjimmy.com
ebay.com or amazon.com
Sanyo 1LG4B10Y04800 Power Supply
TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 16, 2016 | Sanyo Televison & Video
Vulome up cnt adjust
Hi Raven
Is this a Question?
or are you just telling us that the volume won't go up?
Modern TV's are digital computers
So, the volume buttons don't actually turn up & down like in the past.
The internal computer gets up/down values from a register. Then it performs the change to the Amplifier.
SO... the point is
A technician needs to look at it unless you are technically inclined to check the power supply for say "Bulging Electrolytic Capacitors".
Good Luck
How to Replace an Electrolytic Capacitor
Switched mode power supply
Mar 01, 2016 | Sanyo DP26746 26 in. LCD Television
MY SANYO DP50741 POWER BOARD?
i would check to see if the stand by supplies are on the power board and then check to see if the on supply comes up briefly when power is pressed it could be the power board or main board testing the supplies will narrow down which board you need.
Aug 23, 2012 | Sanyo Dp50741
Ive missplaced the tv instruction and need to retune cuould you e.mail me a copy ? the tv is a Sanyo CE32LD47-B
http://uk.sanyo.com/AssetBrowser/Technical%20Database/Instruction%20Manuals/LCD%20Television/CE32LD47-B.pdf
there is your user manual
please take a moment of your time and vote for me, if you found this info useful
Apr 14, 2011 | Sanyo Televison & Video
The green led is blinkin 12 times
Power supply board is dead.Replaced the power supply board will get ur power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply for replacement.
Feb 16, 2010 | Sanyo DP42746 42 in. Plasma Television
DP42746, same as the others!!!!
please never purchase anything with the name sanyo on it again my tv does the same thing now i spent 1500 dollars to have to buy another, should have put that money on a new sony!!!!!!!!! never again i'll tell everyone about these pieces of ****!!!!!!!!!!!!!!!1
Aug 01, 2009 | Sanyo DP42746 42 in. Plasma Television
Digital
If the set is an LCD, yes, it is "Digital" but that only refers to the display. To receive digital off-the-air broadcasts, the set must have a digital or ATSC tuner, otherwise the set has a standard tuner that will no longer work. If the set is "digital ready" a digital satellite/cable/off-the-air converter box must be used, and fed to the set's video input(s).
Did you get fooled? Hard one to answer. It more than likely was the result of the sales person's lack of technical knowledge. "Digital" and "Digital Ready" designations have confused just about everyone since "digital" was first introduced to television.
Hope this clarifies some of the mystery, rhais.
Jun 19, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Picture goes black
are you using the built in tuner or a set-top-box? Or watching DVDs when this happens? Are they connected through SCART?
First check the cables which lead the signal -antenna/satellite/cable if they are not broken or with damaged connectors.
Scart cables sometimes tend to have too heavy and stiff leads for the weak SCART plugs. This is NOT an issue with HDMi sVHS or any other.
If it's none of these the problem is probably a power lead of the screen and if you don't feel like opening the back of the box, it would be just fine to take it over to a repair shop or to the centre where you bought it if you still have a warranty.
if not find a Sanyo service near your location(refer to http://sanyo.com/ ) or take it to any home electronics repair shop.
rate pls
Apr 16, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
Sanyo DS20930 20" TV Logo
87 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
