Need to know proper input requirements..shuts off afte 3-4 seconds when connected to the desktop and shows "disconnector" whn not connected
I may have messed up the message. I would like to know the power requiremenst for a NamSung L19t lcd monitor. this one turns on with the aid of a 12v, 1000ma power supply but turns of after 3-4- second. Thanks and good luck
  • adonyx
    adonyx May 11, 2010
    I need some clarification.
    L19T is a Hyundai monitor model number.
    And I'm not sure Namsung is a real company.
    Please double check that your question makes sense to you and contains accurate information.
  • Dick
    Dick May 11, 2010
    Namsung?
    Problem Solver:
  • 19 Answers
Replace with 9v 3amp. power supply.
Posted on Aug 05, 2009
What causes the car not to start whn crnkng
Can be many things, so you need to run tests. Do you have spark at the plugs? Do you have correct fuel pressure? Is the timing belt broken? Does engine have proper compression? These tests require basic testing tools, and their cost is part of why mechanics charge the fees they do.
Mar 18, 2016 | Cars & Trucks
Dont know the functions of front face usb and mini inputs for HP Pavillion a1700n
To burn a CD you need a CD-burner. The front input are not required to burn a cd.
Aug 03, 2012 | HP Pavilion a1700n PC Desktop
The front 3 usb ports are not working along with all the card readers. In device manager they show to be working properly.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 08, 2011 | HP Pavilion a1130n (PX769AA) PC Desktop
I bought a second hand hand pc from a dealer,it came with 3 cables one cable with a red plug what is it for,the other with a black plug what is it for ,also a cable with two inputs both sides blue in...
Well, all you have to do is make proper connections.
There must be two power cables. 1 for PC and 1 for monitor.
No video input message indicates that the video (VGA) cable is not connected. It is Video input cable, the Blue one with same connector at both ends. Connect it with your monitor and secure it properly. Its other end is required to be connected to the blue output connector at the back of the PC.
Let me know if any further clarification is required. Hope this helps!
CreatuiveTECH
Nov 26, 2010 | Philips Televison & Video
I turn on the pc and it gets to the windows logo then shuts down by itself help pls
dont understand properly, there are2 causes one is restarting after showing Win logo - it means your OS has corrupted and you have to reinstall/repair them (first try with safe mode if still same problem then do reinstall)/ second shutting down (power off) while logo showing - it means your CPU Fan is not running or running very slow/ or CPU heat sink not connected properly, any how the problem with in CPU and the Fan check them and problem will resolved.
vote me if found helpful.
Oct 30, 2010 | Acer Aspire T650 (AST650UC3601) PC Desktop
Viewsonic vx2835wm monitor, in DVI mode connection, altough getting signal from the PC(Other monitor connected and tested for graphic card problem-No graphics card problem!!) , Prompts "No input-signal"...
You will need to change the resolution of the screen on the computer to 800-600 and the bit to 24bits or 16bits, to do this right click on the windows screen, and click properties, goto settings.
You should see a slider at the bottem left of the screen to adjust the resolution, and a drop down bar on the other side for the bit rate. This should solve the problem, also you could open the scond screen also in the display properties, and drag what you need to see on the screen to that screen, you will know what i mean when you open screen 2 it just expands the desktop. hope this helps.
Aug 21, 2010 | ViewSonic VX2835wm Monitor
I cant record TV
Proper setting is required. This time i don't know what connection you have, in case you use RF IN, fine tune your VCR's Tuner to the desired channel you wish to record. If you connect via A/V IN, select proper input on your VCR. Good Luck
Mar 01, 2010 | Televison & Video
Monitor wont connect to pc only disconnector error message
How this happened ?
Check the cable connecting your monitor to your VGA !
Are there maybe two connectors on your VGA ?
Try the other one.
Is there a beep when you turn on your computer ?
Are there more than one beep when you turn on your computer ?
May 27, 2009 | IBM ThinkPad T43p Notebook
GE SPACEMAKER MICROWAVE JVM1440WH02 SHUTS OFF 5 TO 10 SECONDS AFT
my mother had a fire in her micro. Now it doesn't work....please help. thanks. sandy
Apr 06, 2009 | GE Microwave Ovens
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
