Question about KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer
MIXER WILL NOT RUN AFTER CLEAN/LUBE TEN YEAR SERVICE.
After ten years of use, I decided it was time to clean and lube all the internal parts. The motor still looks new inside and the gearbox and it's grease look fine as well. However, once it was back together, it would not run! PLEASE explain to me how the speed control works...I was expecting a reostat or an actual SWITCH!! It does hum..when first turned to the lowest speed but thats it! The speed control is clearly adjustable... but what is the correct setup? Thank you in advance..H.Moestein.
  • 72 Answers
The speed control is a governor setup, it's purely on and off, as the weights on the motor shaft spin faster, they press against the contacts, and when they spin a fast enough speed, it turns off current to the motor, which makes it slow down, and current gets turned back on.  That way, you get a pretty consistent speed on a setting no matter whether it's lightly loaded or whipping something fairly heavy.  If you can turn the motor shaft by hand, then you don't have anything binding, but you might have gotten the speed control out of adjustment.  give it another go.
Posted on Oct 20, 2007
SOURCE:
How doI fix mixer that leaks oil out beater holes
There ate two ways to fix this problem, but first there is the matter of understanding what is leaking. The oil you see leaking is actually a food safe vegetable based gear grease. The grease separates during heavy use (years of service) or when the mixer has not been used for an extended period of time. (months or years) The recommended way to fix the problem is to do a full tear down then clean then add new grease and a new gasket, cost (By Kitchenaid at a KA service center) around $140.00 US + or -, It involves shipping and around ten days in time. The second way is kinda simple and does not cost anything. Get a towel, thick and soft to protect your finish, get your wife or husband, get an extension cord, spread the towel out on an open counter top, plug the extension cord into the outlet, turn the mixer upside down on the towel, have your significant other hold the mixer by the base while you plug the mixer cord into the extension cord, turn on the mixer no more than 2 or the second click on the speed control switch / lever, hold the mixer upside down like this while the mixer is running and keep it running for at least three (3) minutes, turn the mixer off and turn it right side up and turn on again for two minutes, then do it again two or three more times, upside down for a couple minutes then back right side up and so on and so on, after about 15 minutes stop. put everything away, you are done. What you have effectively done is re-mix the grease and it should be good for another couple of years. When it starts to leak again re-mix again. Or send it to KA for the rare and unique opportunity to spend a hundred bucks that you don't' want. hope this helps. By the way if you get some drops in your mix it will not hurt anybody. But you do not want to eat a great deal of it or you will require the use of a laxative afterwards.
Jun 18, 2014 | KitchenAid 32685 Mixer
My mixer seems to leak once in a while a light tan colour liquid from where you put the mixers in the round chrome ring around that on the inside.
Your mixer has a vegetable based lubricating grease in it, that grease can separate from time to time. One way is non use the other way is end of life from normal use.
If you do not use your mixer regularly, get a towel and put it on the counter, get your mixer and turn it upside down on the towel (to protect the finish) turn the mixer on while holding up the mixer (balance it) run the mixer for 2 minutes on speed 6, shut it off and turn the mixer rite side up and turn on again for 2 minutes, then repeat the process at least once. If your mixer continues to leak your lubricant is at end of life and it needs to be replaced along with a new motor housing gasket. KA will service it for you for about $100 dollars, you can do it yourself but it requires a full tear down of the mixer, you may have an "after warranty" service tech in your area but you will have to look for small appliance repair shops. If you do it yourself it will cost you about $20.00 bucks and a roll of paper towels as it is really messy. There are videos on utube that will show you how. The process I described above is a simple re-mix of your existing grease and in at least 60% of mixers I have repaired this is the problem with leaky oil / grease, it will last two or three years before it starts to leak again, longer if you do not use your mixer much, The grease is food safe and will not hurt you or anybody that may eat a recipe that might have a drop in it. But yes; I know it isn't really appealing to have grease dripping in your cooking. So the first thing to do is try and remix your existing grease, then try baking with it, if the drip has stopped your OK for a few years. If not you need to re-pack the grease and change the gasket.
Also the existing gasket is fiber and when the machine is put together the screws that hold the upper and lower motor housing parts together is not torqued down very hard (that is intentional on KA's part), the weight of the upper motor housing is about ten pounds and after years of having the mixer sit on top of the gasket it compresses and allows the grease liquid, (once it separates), to leak out and to get all over the place.
If you do decide to take your mixer apart you might try to just tighten up the screws that hold the two pieces together and try the re-mix process, that solution works on about 20% of all mixers I have repaired. Do this if you don't want to spend the 20 bucks on parts and grease. Let us know if this helped.
Mar 17, 2013 | KitchenAid K45SS Classic Stand Mixer
I was given a Kitchen Aid 45SS mixer that is over 20 years old but never used. Is there oiling or other maintenance procedure I shoild perform before using? Thanks. Chuck Volkema
I read thru the owners manual for this unit and there is no recommendations for internal service. no reference to lubrication except for keeping the outside free from flour caking up on the moving parts. I have one of these and have seen the inside, they are built like tanks, you should be fine. i would recommend letting it run for a while on low speed to speed the lube around the internal parts, nothing more should be needed. Just make sure it doesnt sound as if the motor is laboring on low speed, this would indicate that internal lube is necessary. I think it will be fine...Worm1855
Jan 18, 2011 | KitchenAid K45SS Classic Stand Mixer
My d300 hobart mixer is dripping oil when I am using it. How can I stop the oil from dripping out
It uses grease which breaks down over time. The transmission has to opened up and all of the old lube removed and replaced with fresh lube and the bottom seal replaced. Contact your local Hobart office. www.hobartservice.com to locate your local office.
Nov 04, 2010 | Hobart D300-6036 Mixer
I hAVE A HOBART 200T FIRST AND THIRD GEAR WORK FINE BUT SECOND GEAR DOES NOT SEEM TO GRAB WITH ANY TORQUE. WHAT MIGHT BE THE PROBLEM?
I would say without looking at it a key is sheared or gear teeth are worn on the gear.usually its a sheared key,however if the mixer is older they use a dive key assembly which you would have to replace the shaft.I'm a hobart tech and repair these mixers often,any ? let me know.What is the ml # on the data plate?
Nov 13, 2009 | Hobart A200 Stand Mixer
I have oil coming from the front of a hobart a200 mixer,What to look for? and what kind of oil?
If you have oil leaking from the attachment hub, the transmission grease has liquified. The transmission will need to be opened so the old lubricant can be removed, by scooping it out. There aren't any seals in the attachment hub, just two torrington needle bearings. The helical gears thrust the pinion gear onto a thrust bearing in the hub to create a seal. The hub has a return hole in it's casting for excess lube to return internally. It's possible the return hole is restricted. On the other hand, if the machine has been filled with oil, it will probably leak like a siv.
The new lube should be 35 OZ of mobil XPH 222,
Hobart part number is 103881-47 for 32OZ.
Aug 04, 2009 | Hobart A200 Stand Mixer
Kitchenaid mixer stopped
Hi Myrna. You may have overloaded the mixer. Don't try to use it, as you may do further damage. If you're hearing the motor turn, then it's OK. There is internal damage in the transmission area. Call Kitchenaid to find the nearest "authorised" repair place. Kitchenaid no longer has a parts catalog for the KSM 90, so parts may be hard to find. Call the "authorised place and ask if they have parts for your unit. Ask them if they can get parts for your model. If they say no to either question, call other small appliance repair places locally and ask the same questions. There may be spare parts around. The fact that Kitchenaid no longer has a parts catalog means that they consider it obsolete.
If you find that It cannot be repaired. I suggest you look at other brands to replace it, as Kitchenaid is now owned by Whirlpool Corp. and the quality of the Kitchenaid line is not what it once was when they were built by Hobart.
Goto www.consumeraffairs.com and review the different mixer's pros and cons. Good luck! ricardok45
Apr 03, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
How to maintain 80 qt mixer?
operators manuals are available on the hobart service website, it will tell you to lube the side rails twice a year and other operator level maintenance.
Aug 20, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart A 200 Mixer - Lube
HI Joe
I have the wrong greace in my A200 standmixer i need to know what kind and how much to put in gear cace. thank you
Jul 17, 2008 | Hobart A200 Stand Mixer
New (old) N50 ML-4749
You should be able to purchase the manual. I know that Hobart abandoned that policy a few years back -- unless they re-instated it. Call Mother Hobart and ask. 937-332-3000
There is a few tricks to these units, it would be tough to convey here. But here goes...
Remove back cover. Loosen 6 or 7 screws around outside of motor windings. Thump the nose of the mixer downward to break the seal. Watch for spacer washers where shafts go into motor case. Remove spring. Remove idler. Remove shifting guide. Remove gear assy. Leave beveled gears in place if possible. Clean. Use Darina II grease. (20 oz) Clean and permatex "seal". Tighten mounting bolts. Adjust set screw at back of planetary. (Double set screw. The first one is to lock the adjustment.) Test in 1st and then 3rd while turning the set screw. You just make it quiet for a proper adjustment.
Good luck -- Mike
Apr 28, 2008 | Hobart N50 Stand Mixer
KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
275 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
