Question about Whirlpool LHW0050PQ Front Load Washer
Door is jamed closed ? broken handle on hotpoint bwd129
The plastic catch on the machine has no resistance but i'm not convinced the machine is releasing the temp. controled door lock either!
please help, i've heard hotpoint are not the best with their after sales and dont want to wait for an engineer to come out if i can help it!
many thanks.
jsrock516
  • 5911 Answers
SOURCE: whirlpool washer problem with door
I believe you are talking about the lid switch. To replace follow these steps: 1. UNPLUG the machine first. 2. Remove the console. You will have one of two types of consoles with two separate methods of removal. a. The first type is a matter of removing the two end caps of the console by lifting up on the end cap from back behind the console and pulling towards you. The cap should just pop off. There will be a groove present on the top rear that you can gently pry with a screwdriver if you can't remove by hand. You will need to remove the philips screw under the end caps and the console will lift up. Be careful not to break the plastic hinges that hold the console in place. You can lift it up and lay it back over the rear panel in a resting position. b. The second type of console (usually found on some of the newer models) has a retaining clip under each end cap at the front corners. You will need to carefully slide a putty knife between the end cap and top of the machine from the front. Push in to release the retaining clip and lift up. This may be a little tricky trying to get both ends to release together. The console lifts up in the same manner as described before. Again, be careful not to break the plastic hinges that hold the console on. 3. You will find two brass colored clips under the console. Place a flat blade screwdriver in the clip groove on the washer top and push away from you. This will release the retaining clip that holds the case to the back of the machine. Remember how they came off, because you will need to put them back in. 4. Disconnect the lid switch plug from the connector. This is a white plug that is mounted physically to the washer top casing. 5. Lift the lid and place one hand under the front rim of the casing and pull up from the rear towards you. The entire casing should lift off the frame. 6. The lid switch is located on the right side of the machine in most washers. Some are located in the back on the left hand side. In either case they are fairly simple to remove. There should be a couple of mounting screws and a ground wire to remove first. Then the switch (with harness) should come off. You will need to carefully remove the connector from the casing by using a small screwdriver to release the tabs holding it in. 7. The new switch will install using the reverse order of the steps I just mentioned. 8. Placing the case back on the frame can be tricky. Lift the lid again and place one hand under the front rim of the casing. Looking down through the lid, place the front of the casing UNDER the frame first and slowly lower the rest to the back. There are two cleats on the frame that must line up with two holes in the casing. Once the casing lines back up on the frame, set it down all the way and pull the back up to meet the casing so you can place the brass retaining clips back in. Place the clips in the groove on the back first, then push down until they snap back into the hole on the washer casing top. You may have to use a little effort to get them back in. 9. Reinstall the console. I know this seems like a lot, but it should help you replace the switch. Getting the machine case to line back up is the hardest part of the procedure, but you can do it if you take your time. Let me know if you have any further questions.
Posted on Jul 17, 2007
  • 1073 Answers
SOURCE: The door will not stay closed, even during cycle
replace the door lock switch part 8182634
Posted on May 03, 2008
micromaster
  • 3614 Answers
SOURCE: The catch on my washing
Hi there.
check for the interlock switch
Posted on Jun 01, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint bwd129 how can i open the filter at
If you have located the fliter, then grasp the filter cover, and twist and turn to the left to remove the filter
Please rate my solution.
Thanks.
Posted on Jul 21, 2009
SOURCE: Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Posted on Jul 23, 2009
Hotpoint tdc 30 door catch will not push into door switch when I close door, have taken switch out and it fits into catch manually but not when it is installed so door will not close to activate drying
I would say that the problem is due to the door handle spring being weak or broken.
Purchase a door handle kit, and it should solve the problem, if it does not, then you need a new door switch.
Hope this helps with your problem.
Dec 09, 2009 | Hotpoint NVL333EY Electric Dryer
How do I repair the handle on a Hotpoint Aquarius? The handle has not come off just door catch is broken.
Remove all vvisible screws securing both parts of door, and seperate the 2 halves, be careful you do not drop the door glass.
This will enable you to see what is broken, and what needs to be replaced
Thanks.
Nov 04, 2009 | Hotpoint Aquarius WD640 Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint BWD129 stuck in rinse phase
Problem was caused by a faulty water temperature sensor. The clue was that the owner reported increasingly hot washes, then the machine stuck at rinse. A test resistor replacing the sensor allowed the cycle to finish. A replacement sensor is on order.
Jan 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius 1000wm 20 I have to bash front door to start
I do not think it is the door lock that is faulty, more likely to be a weak or broken door spring or broken door catch.
I would replace these first,and then if it is still the same, then replace the door lock.
To replace the spring and or handle catch, undo all the screws that secure the 2 halves of the door, and prize apart the 2 halves,
Replace the spring and catch, reassemble the door.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius w.machine door catch broken.
easy way is to cut or break away the handle so the start of the door peg is exposed and use a screwdriver on the peg to lever it out
Aug 30, 2008 | Hotpoint Aquarius WF000 Front Load Washer
WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Dec 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
291 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
