Question about Canon MP-25DV Calculator
How to open to change ribbon on a Canon mp25dv
Remove the paper tape by pulling it back out of the calculator.
Feel along the back of the calculator right below where you insert the paper tape for a ridge. Gently lift up on this ridge and a plate will lift out of the machine exposing the ribbon.
Make a note to yourself as to how the old ribbon is in the machine before removing the old ribbon. Just gently lift straight up on both of the spools and the ribbon will lift out of the machie.
When you insert the new ribbon make sure that the ribbon is feeding off of the back side of both spools. You can use a small screwdriver or toothpick etc to position he new ribbon to keep the ink off of your fingers. Make sure the new ribbon feeds around the plates on both sides of the machine and it fits behind the roller that has all the numbers on it and that the red portion of the ribbon is on the bottom.
Take the plastic plate that you removed first and insert the tabs in the front underneath edge of the case on the front and gently push the back side of the plate straight down till it smaps into place.
Refeed the paper tape back into the machine and you are finished!
Hope this helps.
Posted on May 28, 2009
  • sdevine41157 May 10, 2011
    Thank You. I could not even get the calculator open. But when you wrote how to open I had to pull hard. Thank you.........
  • Gibraltar Mar 16, 2013
    Thank you very much. I was able to change the ribbon using your instructions.
My canon mp25dv calculator will not power on
Check the connections, battery, photo cell, etc.
Is cheaper to replace those than tinker with repairs.
Apr 02, 2018 | Canon Office Equipment & Supplies
CANON mp25DV calculator...changed the ribbon, print is no darker than before I changed it
There is a setting for darkness. Check it out in the manual or directions.
Sep 18, 2017 | Canon Office Equipment & Supplies
When I print the numbers come out faded, I changed the ribbon is there a way to fix this?
Your ribbon is not seated properly. I would look to make sure you have fed it through all of the guides properly. If this is not a snap in cartridge then I would make sure that the ribbon is feeding the right way and is not upside down.
Feb 25, 2015 | Canon Mp25dv Desktop Calculator 8077a006ab
How do I put a new ribbon in a Canon MP25DV
Top right column on page 3: http://www.manualslib.com/manual/355936/Canon-Mp25dv.html
Feb 05, 2015 | Canon MP-25DV Calculator
What is a ribbon on cannon mp25dv
http://www.staples.com/Dataproducts-R3027-Universal-Calculator-Ribbon/product_867590
Dataproducts R3027 Universal Calculator Ribbon
Item: 867590 Model: R3027
$3.99 Ribbon Only
Sep 12, 2012 | Samsung GT E1080 Cellular phone - GSM -...
Need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
Apr 27, 2010 | Canon MP-25DV Calculator
How do you set the date and time?
1) press calendar clock button
2) hold the time and date button for 3 seconds, this button is marked with "Time and Date" one the keypad and not on the button itself
3) The date or time should start blinking
4) make inputs of current date and time
5) press Time and Date button again to save changes
6) All set!
Anytime you want to display the date or time hit the clock and calendar button. The calc will hold the display until u switch to the calculation mode i.e. by pressing the CE/C button.
DUHHHHHHHH!!! All these instructions are in the piddly sheet Canon calls the manual.
Dec 28, 2009 | Canon MP-25DV Calculator
How do you set the clock/calendar on the Canon MP25DV?
The trick is to hold down the time set button (=) until the time flashes and once the new info is entered, press time set and it will stay.  same with the date.  You kinda need to play around with it.  Thats how i learned.
Mar 24, 2008 | Canon P200-DHIII Calculator
Canon MP-25DV Calculator Logo
4,512 people viewed this question
old marine
old marine
