Question about Kenmore Elite 45986 Front Load Washer
Moved Washer and Now no Electrical
Washer was moved to new home and I tried to install tonight with new connections, etc. Won't turn on. Worked fine yesterday at old house. The electricity in my new (very old) house is fuse box quality. Tested the outlet and it is hot. Does the washer have to have a special outlet to work? I keep reading about 120 volt 60 hertz. Or was the thing broken in route? I have kids and I really need my washer and I really don't need another bill. Thanks!
  • kpm4 Sep 22, 2007
    Thank you for your help. I used a poor choice of word with hot, I meant that the electricity was running (I checked by plugging in a nightlight.) I hadn't thought to check if the machine plug was well connected or screwed in. I'm off to give it a shot! Thanks again.
    President:
  • 1,294 Answers
Suggestion: You dont need any special outlet. With a tester (you can get this in any electric shop) see if there is power in the outlet. You said it was hot?? It is not supposed to be hot. Try another outlet; & you could unscrew your machine plug to see if all the three wires are okay, ie. well connected, screwed in.
Posted on Sep 21, 2007
After moving dryer to new apartment, worked at first but now won't turn on
Did you check the power source? You could have popped a breaker (or fuse) if the dryer circuit in the new apartment is inadequate. Might have been good for one shot, then no more.
Sep 03, 2012 | Maytag Dryers
My 42LD450 won't stay on! It turns on for a few seconds and works fine, then the screen flashes then comes back on, then flashes again after a couple seconds, then turns off. Rinse and repeat. Tried...
I hope that you can use the warrantee.
Otherwize, it must be possible to repair it with a fried comfortable with electronic because the problem is not permanent. This kind of problem is usually an old capacitor or a bad connection (soldering).
It would be important to check if changing the ambiant temperature fixes the problem. (I.E. move it to the seller for 2h and try..)
Regards,
Jul 10, 2011 | LG 42LD450 42 in TV
Okay, my fisher and paykel gwl15 is almost brand new. i moved it into my new house tonight. I tried washing my laundry and it starts to fill but then stops at the light that says "wash" and wont...
Sounds like you have low water pressure or a blocked hose inlet screen. take the hoses off and check to see if there is any debris in the screen on the washer hose connection. Make sure the hoses are not kinked and the valves are turned up all the way. Also check to see if you have those special flood proof hoses with the automatic water shut offs. I have had those not work properly many times.
May 18, 2011 | Washing Machines
I moved my TV from my old house to my new house. Before it worked just fine at my old house, brought it to my new house and it just doesn't turn on! Tried different outlets, wires, etc.
Check the power at the plug point. Check the plug of the TV. If there is no life, then you will need to open the TV panel and check for a blown fuse, a circuit break while transporting, a loose connector within the set or a possible damaged SMPS>
check this link below for some tips on the power supply:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 21, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
I cannot display either Windows explorer 7 or 8 home page. All the functions (hotmail, favorites,google, etc) work in Explorer 8 but when I try to go to the home page I get "Internet Exployer cannot...
Hello
Thank you for using
FixYa for your problem
ok, is it only the Home page not working, if you manually type in a website you do get there page.
I am thinking the Home page link is a old link and now dead. manually type in the address for the home page and see if that works
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Microsoft Internet Explorer 8
Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Apr 21, 2009 | Bose Lifestyle 48 System
Not finding satallite
DL a quickGPSfix from tomtom home and reset to factory settings if that does not work but it should
Jan 01, 2008 | Tomtom ONE GPS Receiver
Kenmore Elite 45986 Front Load Washer Logo
97 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
