Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
The color is screwed up
Our 57" Hitachi is 5 years old and all of the sudden the color has been screwing up. It seems like there is a color that is not working everything is really bright reds and oranges. It did it a week ago and we turned it off for a day or so and it was fine now it is doing it again. Someone help please?
    Scholar:
  • 71 Answers
The projection TV has 3 color guns that focus to produce a single image. The 3 colors are red, green and blue. It sounds like the blue gun went out. You should be able to remove the back panel of the TV. If doing so, use caution as there is a mirror attached to the back panel. Once removed, you can confirm that the gun is not working. The fix, unfortunately is neither easy nor inexpensive. The problem could be simply a poor connection to the circuit board up to needing the replacement of a new light or perhaps a new gun. Unfortunately, there is no magic button to press and nothing you are doing wrong. This is a very nice TV and it may be worth getting an estimate to repair it. Or, perhaps this is a good excuse to go out and get a new 50" plasma! Hope this helps. If you can think of anything else I should know, please comment.
Posted on May 04, 2009
What is the life expectancy of the Hitachi 51F500
5-10YEARS. THAT TV SOLD FRO 999.00 AT ITS END RUN SO YOU MIGHT WANT TO THINK ABOUT REPLACING IT
May 21, 2009 | Hitachi 51F500 51" Rear Projection...
How hard is it to open up a Hitachi 57: Rear
there are just a series of screws to remove the the back and the whole thing opens up. Not sure what to have you used to clean the bulbs off probably just a clean soft electronics cloth. No alchol or windex.
Mar 27, 2009 | Hitachi 57S500 57" Rear Projection...
Color alignment
This sounds like a convergence problem. Would you describe the picture like a 3-D one? If you can solder, you should be able to fix this yourself. Let me know if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Mar 26, 2009 | Hitachi 57F500 57" Rear Projection...
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi loses color
you are losing one of your color tubes for it to be goiing to black and white.
Jan 27, 2009 | Toshiba 57H82 57" Rear Projection...
Hitachi model 57F500A
Your unit uses a Cathode Ray Tube (CRT) for each color.
Since you didn't say that it was a gradual change, I suspect the CRT filament has failed open rather than a slow death of internal emissions.
Considering the very high level of light asked of these CRTs, I am amazed they last as long as they do.
The replacement and almost certain necessity of initial alignment and color balance, this is beyond DIY possibility and is likely going to be fairly expensive.
After 5 years of use, the other CRTs are somewhat (if not a lot) degraded so don't be surprised when a tech advises replacing them all and I think it may not be a whole lot less expensive than replacing the set although looking at the specs for that set indicates it is not obsolete by any means.
May 21, 2008 | Hitachi 57F500 57" Rear Projection...
Thin red horizontal lines across screen
While looking at your TV, remove the bottom right speaker grill. There you will find a cover held by a couple of screws. Remove the screws and behind the cover you will find the "focus pack" which is a group of 6 adjustment screws. The top screws adjust (in order from left to right) the brightness of Red, Green and Blue.
What you will do preferably at night (or with the room dark) turn the top left adjustment screw (Red) all the way to the left and then gradually turn it to the right until the point you can see the retrace line and then turn it slightly to the left until the retrace line disappears. That's it! You can do this for all three colors - if need be. These do go out of adjustment every now and then. The 3 screws on the bottom are to focus the colors individually to minimize "bloom" on the screen. It's best to be in service mode on your TV when doing this OR open up the cabinet and cover (with something) the other 2 colors while you adjust the focus of the color you're adjusting.
Good Luck!
S
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Adjustng crt colors
put on a black and white channel and adjust to best black and white
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
Bad picture
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 26, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
158 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
