Question about Directed 2400d Car Audio Amplifier
Protection light stays on
I had a loose wire form the d2400 amp while i was away someone connected it for me i came back and the amp is on protection mode i checked the wires to the sub and realise that it was negative to positive all the fuse are ok and all the other connections are fine do i have to get the amp repaired
  • leerodney Apr 21, 2009
    so easy i did what you said but made life easy for myself i removed all the fuse 3 of them in total went to the pub came back and re inserted them making sure that i checked everthing was connected properly , the red light flashed until i put the head unit on then it went green and it was on in 2 mins thanks for all of your help . i was about to take it to the shop to be repaired
  • leerodney Apr 23, 2009
    i have a directed 2400d mono amp driving a 17 inch square sola barrics
    Problem Solver:
  • 8 Answers
Not unhook the amp completely let it sit for 15 minutes it should reset it self and rehook the amp starting with ground rca and remote than the power last it should be back to normal
Posted on Apr 21, 2009
  • gsxking Apr 23, 2009
    no problem glad i could help...thats a good way too but most amps wont reset like that what kind of amp do you have kicker mtx jl
Subs cut in and out
The amplifier may be going into protect mode (even briefly) because you are driving them too hard. Back off on the volume and see whether the problem goes away.
Mar 11, 2017 | Alpine MRP-M1000 Car Audio Amplifier
Kicker zx750.1 protection mode
Well, check again for lose wires and make sure it is grounded good and let me know what you find, Make sure you check ALL of the wires.
I will be more than happy to help you when you get back to me on this.
thanks
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Hi i have a kenwood A-97 keeps saying protect on the amp can you help
The amp will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. verify that none of the speaker wire connections are loose at the back of the receiver or at each speaker. And verify that none of the wires are making contact with each other.
if it is, then remove the speaker wires and connect them again properly. After disconnection g the speaker wires, unplug the receiver for 10 to 15 minutes. This will make the overload protection back to normal
Try this and let me know. I hope this would solve the issue
Regards.
Jan 04, 2012 | Car Audio & Video
I have a punch p850.4 amp that goes into protect mode as soon as its powered up , have checked and double checked all connections to make sure its all hooked right . even downloaded the pdf for the amp .
I have exactly the same problem, try a different speaker wire from your sub terminal to your amp terminal, if no luck you may have a loose connection on the wires on your sub, due to vibrations etc they can sometimes come loose, but very rare. worth checking though. 1 loose connection can make the amp go into protection mode. If all of these are fine, start from the beginning, ( I have tried this and i think its my speaker wire shorted out) 1st dissconnect all wires from amp. Then connect ground first, then your live. then power up amp, it it works andd not in protect mode your earth and live are fine, then connect your remote, then test, then speaker wire , then test, that way you can rule out bad connections and find any fault.
Mar 03, 2011 | Rockford Fosgate Punch P850.4 Car Amp
Trying to increase volume on car deck when doing so the amp just shuts off, then amp makes a burning popping sound and smells like something burnt up and 3 sec later amp kicks on and still works, none of...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Please check impedance on speakers as they coyld be fried as well. A thumbs up would be greatly appreciated if this answer is helpful to you
Oct 03, 2010 | Orion HCCA-D2400 Car Audio Amplifier
Unit only stays on for 4 seconds then turns itself off.
This is a short or unstable ohm load. Remove all speaker wire connections to see if the amp will stay on.
If the problem goes away when disconnecting the speaker wires try this:
1) Check volume level on zone one and zone 2 if connected. If it is too high the amp will go into protect mode and shut off exactly as you described.
2) Make sure no wires are touching any other wire or the metal surface of the amp. This will cause a short and send the amp into protect mode.
Nov 21, 2009 | Denon AVR-1705 Receiver
My amp turns on and off
Sounds like there could be a short somewhere. Check to make sure that there aren't any (exposed/bare) wires touching each other or if there is a bare spot of wire touching something metal. Check both ends of all the wires. A speaker wire may have come lose and is shorting out against the frame or some other place. Usually if it goes straight into protection mode or you're popping fuses you have a short somewhere. I assume the capacitor you installed is somewhere on the power line, which would be for helping with
noise. You can also try disconnecting your amp from your stereo and see what happens but leave the speakers connected, you don't want to run the amp with out a load on it (the speakers). If your amp doesn't go into protection mode when the stereo is disconnected, then you have a problem with the stereo and not the amp, assuming you already checked for any possible shorts first.
Jun 15, 2008 | Pyramid PB1236GX Car Audio Amplifier
Protection Light Is Coming On
You say the protection mode only occurs when you plug the RCA's in. Does it have to be both RCAs or just one?
The other end of the RCA cable is plugged into the HU?
It possible the RCAs have too much DC voltage on them, causing the amp to go into protection.
Is there a short in the RCA cable?
I would definitely check out the RCA connection at the back of the HU, as it sounds like there could be other issues there. Make sure the RCA connectors aren't touching any other metal (especially +12V).
Mar 14, 2008 | Car Audio & Video
Shuts off protect mode
i have a jvc stero and every time that i turn it on ...it show protect and shuts off!
Jun 25, 2007 | JVC HX-C6 Shelf System
Amp goes into protect mode.
I would definately suspect wiring. If you can use a volt meter. Put it on the b+ to ground and see what the reading is should be 12+ then try the ground to remote wire should be 12+. If it drops below 12 volts when car starts. Recheck wires for loose connection. Also double check the wire you have the remote wire connected to. You might even want to disconnect from the amplifier and use a jumper wire from the positive terminal on the amp to remote on the amplifier and see if it stays on then. If it stays on you will have to find the loose connection or find a different wire to get remote power.
Feb 05, 2007 | Crunch V-Drive V-2800 Car Audio Amplifier
Car Audio & Video Logo
224 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
