Question about Refrigerators
Knocking noise I have a Kitchenaid model number KSRI25FNBL00 that started making a knocking noise. I was told by a local repair person I needed a new ice maker due to a brocken gear. However the noise sounds more like a knocking on a tube or piece of wood. It does not sound like a brocken gear. Thank you in advance
    Welcome Back:
    Visited the website for 2 consecutive days.
Ice build up behind the air flow panel in the freezer part of the unit.
turn off the frig. and defrost it. lots of water to mop up.stpped the knocking. look at the parts manual and take apart for faster defrosting.
Posted on Dec 04, 2015
    Problem Solver:
  • 9 Answers
It could be the compressor
Posted on Apr 20, 2009
Kitchenaid superba ice maker not making ice
Put some water in the tray. Let it freeze and once frozen will the ice then empty into the ice bin? If yes then the problem is possibly one side of the water control valve is defective. This is not the correct water control valve for your model number. HERE You need to provide the correct model number first.
What is the model number? I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | KitchenAid Refrigerators
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
Kenmore 106.55242400 ice maker knocking noise
most likely you need a new ice maker,one thing that could do this is the white arms that spin around when dumping the ice,sometimes one of the arms bend and jam the ice maker and you'll hear that knocking soundthe arm gets bent,the ice cube gets stuck because the arm can't push it out,,it stops the motor from spinning through it's full cycle and damages it but this is just a guess from something i've seen happen but most likely you need a new ice maker,one other i've seen is the metal arm that you can lift up to shut off the ice maker gets knocked out of the hole it slides into.if you pop off the white cover and get a jumper wire and stick it into the h and t holes you can jump start the ice maker.http://appliantology.org/gallery/image/659-manual-harvest-on-a-whirlpool-modular-ice-maker/
Jan 02, 2014 | Whirlpool Refrigerators
ICE MAKER
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
May 30, 2012 | Refrigerators
Ice maker makes knocking noice
It would depend on the model of your fridge. Most fridges, you would just need to change the icemaker, but if it is a whirlpool or kitchenaid, you can just replace the module on the front of the icemaker (part number 8201515)
May 19, 2012 | Electrolux Refrigerators
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Ge profile artica constantly knocking
Broken internal motor mounts in compresser.
Jun 03, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
954 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
