Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Freezer only cools to 40 degrees
My large upright frigidaire freezer only cools to 40 degrees
    Problem Solver:
  • 9 Answers
Check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
Posted on Apr 20, 2009
The fan on my frigidaire 20.0 cu. ft upright freezer (LFFU2065DW7) keeps running.
Good Afternoon Brian, thank you for your inquiry!
Generally speaking, it is normal for the fan to constantly run. The fan will run whenever the freezer needs cooling. This can vary between 60 through 90% of the day. I hope this information helps to some degree. However, should you feel that a service technician is needed; you may visit the manufacturer website to find a provider in your area that will look at your unit.
Best regards!
Oct 24, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
We have a model ffu1152dw, 11.3 cubic feet freezer. This morning it was not running. Then I pulled it out and it started up again. But it is not cooling down very fast. Has been running for about 6 hours...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
It doesn
switch problem in engine or try bring to nearest service center
Apr 03, 2010 | Frigidaire Freezer Refrigeration White...
My frigidaire side by side isn't cooling properly,
Feb 21, 2010 | Frigidaire Freezer Refrigeration White...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
My frigidaire FFU20FC6AW7 is not freezing. sides are cool to the touch and they are normally hot. cold air blowing out about 40 degrees.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
670 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
