Question about Ricoh SP C221SF Aficio Printer
Ricoh Aficio C221SF EResults Error 100021  I get this error rssult code when i try to fax something.  Any Clues?
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
SOURCE: ricoh aficio 2022 error code sc542
I have a Aficio 551/700 and the display reads SC124 anyone have a suggestion on how to re-set this
Thanks
ES...ASD
Posted on Feb 08, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh sp C221SF Error code Sc 400
The board that controls it. Probably the IOB. Typically, the code is cause by a dirty ID sensor.
Oct 04, 2014 | Ricoh SP C221SF Aficio Printer
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
How to scan in pdf format using the Ricoh Aficio SP C221SF
In Acrobat proffesional: File/ Create pdf file/From Scanner
Nov 13, 2010 | Ricoh SP C221SF Aficio Printer
Sc 400 code ricoh c221
An sc400 error means the toner mark sensor needs to be cleaned. Cleaning this sensor is easy:
Open the top cover and remove the cyan toner cartridge. You'll see a long black lever with a sort of handle that pokes upward -- slide this lever ONCE to the left, and then it should slide back into place.
Now replace the cyan cartridge and close the cover, and your printer should be fine. (If the error doesn't clear, turn the printer off and back on and it should go away.)
Aug 19, 2010 | Ricoh SP C221SF Aficio Printer
Ricoh SP c221sf Aficio upper misfeed jam? What's that all about? There is no apparent paper misplaced anywhere in the paper path.
I had the same error. In my case one of the two springs in the paper tray was missing (on the floor behind the printer) so there wasn't enough force to push the paper up to the pickup roller. After I installed the spring the error cleared and printing resumed.
May 18, 2010 | Ricoh SP C221SF Aficio Printer
How to enter ''service mode'' on Aficio SP C221SF Color MFP
this is priveledged information and kept away from non service personnel to protect both you and the device from unqualified access and possible damage.
if you have an issue that requires entering service mode please call for a ricoh tech this ensures that you are protecting the investment you have made in purchasing a ricoh device.
Jul 07, 2009 | Ricoh SP C221SF Aficio Printer
I have a SP C221SF printer and no software - how can i install
Click here and download the appropriate drivers. Make sure you save them as something meaningful and in a location that you will remember. You will probably have to unzip these files as well. Once you do that you should be able to add the device via the "add printer" & wizard. Let me know if you need any help.
Nov 25, 2008 | Ricoh SP C221SF Aficio Printer
Ricoh aficio error message 06-06 page not received
its a fax error that states there is a line problem, problem is probably static in the phone line
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh SP C221SF Aficio Printer Logo
831 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
