Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Genie garage door openner won't stop when it goes down or up
My Genie Excelorator garage door openner continues to try to close when it is all the way down and continues to try to open when it is all the way open. It works fine if I manually turn if off when it reaches the top/bottom. Is this a senor problem that I can fix myself or should I call a repairman?
  • 31 Answers
There should be a "travel distance" adjustment screw on the opener.
Posted on Aug 26, 2009
Genie garage door oppener opens 2 feet and stops
goes up two feet and stops and stays there, or reverses and closes?
Oct 11, 2015 | Building Materials
My Genie CM8600 garage door opener runs, but prematurely goes back up. No obstructions, settings adjusted on power head-- maxed out. It seems like it reacts to resistance. Is the motor just old? I r
Try manually disconnecting the door and run the mechisim up and down using the opener..see if it runs the entire length up and down... If it does it most likey the door or its mechinism is binding...good luck
Dec 06, 2014 | Genie Pro Screw Drive Garage Door Opener...
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
Garage door goes up woth remote but will not close with remote
Your photoeye safety sensors are not aligned or have a problem. If you hold the wall control the entire time the door is closing, it should work. Check to make sure you sensors at the bottom of the track are aligned
Jun 27, 2012 | Genie Company Genie& Wireless Garage...
Genie Garage Door will not close (Model H-6000-07)
Try cleaning the sensor lens, that could be the problem too.
Feb 01, 2012 | Home Security
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
I need my garage door openner ID, Genie
On a genie these can be found under the light cover or on the back of the unit's motor head. Thanks BB
Apr 03, 2010 | Chamberlain 940CB Security and Wireless...
Genie garage door comes down and goes back up.
You need a general inspection of all related parts. Make sure none of the track mounting bolts have loosened leaving a misalignment of track segments. CAREFULLY with power off use fingers. turn EACH roller. Something as simple as a bad roller bearing can cause this, even a flat spot on a worn roller. Rollers can be bought at a home supply store. These are 2 most causes.
Aug 15, 2009 | Genie Company Genie 34538S Chain Glide...
Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Jul 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,577 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
