Question about Kenmore 20722
Kenmore 20722 Motor Coupler or Cluch assembly?
My washer will not continue to spin when loaded. Spins at full speed when empty. Will not spin when empty with a little hand held pressure on drum.
  • Shermhookem Sep 22, 2007
    Well, ther coupler was in great condition, I tried to drop the transmission to get at the clutch and gave up for tonight.
    Scholar:
  • 136 Answers
Its easy to check the coupler, i would do that first to make sure then if its ok , well clutch. Kenmores, a.k.a. whirlpool's , are very common to have both problems. Just remove da pump and hoses, then remove the motor and check the coupler.
Posted on Sep 21, 2007
  • Beau  Delony
    Beau Delony Sep 22, 2007
    Yeah prolly the tranny or clutch , there both a pain tho >_<
I need an owners manual for troubleshooting for a kenmore 70 series model 110 20722, serial CK4011186, type 111 When it spins out the wash water and rinse water not all of it goes out? Does it have a...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Based on the 20722 Stock Number, the following might be the Sears diagram site for your washer. Check under the Lid for the exact model number:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
Two possibilities:
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
These models don't really have a filter but I'd check the hoses to and from the pump and inside the pump to look for any obstructions in addition to the Motor Coupler (about a $20 part) and the clutch.
Jul 01, 2010 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore washer spins on gentle cycle but not on regular cycle
It sounds like you have a busted coupler. It's what connects the motor to the transmission. They will bust, letting the machine work unless it's under a load. It then spreads out and the motor shaft spins inside the coupler.
Nov 12, 2009 | Kenmore Washing Machines
My kenmore 80 washer spins just not enough to get as much water out as it should. not even 4 towels model 110-24872300. serial cr 10100 91 type 111
you may want to check, the motor coupler,
this is a three piece part, it sits between the transmission, and the motor and controls the speed
just by being in place..
Oct 13, 2009 | Kenmore 24032\24036 Top Load Washer
Cycle won't complete
Hi
You may either have a broken motor coupler (connects the motor to the transmission) or the clutch/brake assembly is slipping. To test the motor coupler start a cycle, if it fills and agitates, the coupler is ok.
You can check the clutch/brake by selecting the spin cycle, open the lid and press the lid switch down using a pen. When the motor starts check for either a very slow spin or give it a boost by pushing the inner drum clockwise and see if it picks up any speed. If it spins just a little, the clutch/ brake assembly is slipping and will need to be replaced
Thanks for contacting Fixya.com
Oct 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Drum out of balance after repair on 20722 kenmore washer
THESE WASHERS SIT ON A SKATE PLATE PICK UP ON THE TUB A TURN IT A BIT AND TRY IT ONCE IT IS BACK ON THE SKATE PLATE WILL OPERATE PROPERLY
Apr 27, 2009 | Kenmore 24032\24036 Top Load Washer
80 series kenmore washing machine not spinning in spin cycle
You can check the clutch/brake by selecting the spin cycle, open the lid and press the lid switch down using a pen. When the motor starts check for either a very slow spin or give it a boost by pushing the inner drum clockwise and see if it picks up any speed. If it spins just a little, the clutch/ brake assembly is slipping and will need to be replaced.
Feb 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Washing Machines Logo
266 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
